Thread: Central Locking Rear door
  1. Central Locking Rear door
    Mar 2017
    Coventry
    A4 S Line 2009 TFSI<br>Hi All,<br>Has any one corrected the issue with N/S rear door not unlocking with key fob but will open manually from inside?&nbsp; &nbsp;I Have searched for similar fault &amp; have visited wrong Forum Group! any assistance appreciated.
    Davmar
  2. Re: Central Locking Rear door
    Aug 2017
    Australia
    Quote Originally Posted by Davmar View Post
    A4 S Line 2009 TFSI<br>Hi All,<br>Has any one corrected the issue with N/S rear door not unlocking with key fob but will open manually from inside?* *I Have searched for similar fault &amp; have visited wrong Forum Group! any assistance appreciated.
    Looks like the motor maybe faulty
    This is a common problem with these cars
    You will have to get a replacement motor installed
  3. Re: Central Locking Rear door
    Mar 2017
    Coventry
    Cheers Buddy,
    Now have somewhere to start as unsure of locking mechanism i.e. motor or pneumatic?
    Sorry about gobbly gook in original message no idea what happened.
    Davmar
  4. Re: Central Locking Rear door
    Aug 2017
    Australia
    1 other thing do you have vagcom cable
    It will tell you if you have a problem and also check if your power
    To the door column is fitted correctly
    This happened to my daughters a1 it wouldn't lock so I pushed it
    In and all ok
  5. Re: Central Locking Rear door
    Mar 2017
    Coventry
    Hi Jason,
    I dont have the cable but a mate of a mate checked it for me a while ago & nothing evident! I will check door pillar to door connection as you suggest & endeavour to get it checked with vagcom if fault persists.
    Cheers Buddy appreciated.
    Davmar
  1. Question Central locking rear door offside(uk) not working
    By DaleButler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2018, 05:04 PM
  2. Rear door won't lock with central locking
    By go-for-it1 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-03-2013, 12:15 AM
  3. Central Locking on rear passenger door
    By lenmolloy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-03-2010, 08:45 AM
  4. Replies: 8
    Last Post: 19-08-2009, 09:23 PM
  5. Rear door central locking not working...
    By stormbringer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 11:45 AM
