Thread: Passat 2012 B7 1.6 tdi coolant leak
  1. Passat 2012 B7 1.6 tdi coolant leak
    Dec 2015
    Scotland
    11 Post(s)
    Hi folks,
    I have a 1.6 tdi 2012 estate.
    I have owned it since new its now at 182000 miles full vwsh. Since 10k miles it occasionally looses almost the full header tank of coolant. At first it only seemed to do it on cold nights and in the morning the light would be on and the tank empty (but not the full system).
    Anyway it did it so rarely I would just top up and VW and our local indy could not find any issues. Now during this very hot weather it seems to be doing it every other day, I have seen a few drips on the floor but can't track where they are coming from.
    It has had the timing belt done and water pump and that did not change anything.
    I realise this is almost impossible to diagnose over the internet however are there any know issues for leaks worth looking at for this car?
    Any help appreciated!
    ps there are no head gasket warning signs such as pressure in the pipes, mayo on the oil cap, pressure or bubbles in the header tank etc etc.
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Passat 2012 B7 1.6 tdi coolant leak
    1840 Post(s)
    You need to have it pressure tested.
  3. Re: Passat 2012 B7 1.6 tdi coolant leak
    Jan 2016
    Winchester Hants
    29 Post(s)
    I had a very similar problem with my old Audi but it never showed any water patches on the ground. When I removed the plastic engine/sump shield I notices that the steel lower rad outlet fitting had rusted so much so that it seeped water. The small amount of water either steamed off or dropped onto/into the plastic tray where it stayed until I drove whereupon it just flew aft. I never had it fixed because it looked a major task but just kept filling the reservoir every week.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  1. Question Audi A6 SE - 2012 - Using to much coolant
    By petbul in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-10-2017, 10:04 PM
  2. 2012 Jetta 2.5 power steering leak
    By heramienta in forum Golf MK6 - 2009 - 2013
    Last Post: 14-09-2016, 12:27 AM
  3. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  4. 2012 Audi A3 1.6tdi coolant loss
    By Mccandless111 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 31-03-2014, 06:33 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
