Thread: Estate - Rear Number plate lights
  1. Estate - Rear Number plate lights
    Jul 2007
    Co Durham
    Checking my rear number plate lights because one of them was out, I found that the plug on the end of the wiring harness, and the socket on the actual light fitting itself were badly corroded. As well as a new light fitting, I need a new plug on the end of a few inches of wire. It doers look like it may have been replaced before as there are soe crimped connectors about 3 incjhes up from the plug. If I get a standard light fitting, where can I get a plug on the end of a few inches of wire from? Alternatively there seems to be all sorts of LED lights available on Ebay. Are the number plate lights for an estate the same as for a hatchback? Can I get LED lights and just patch them into the existing harness? Thanks (Post on the Golf 6 pages as well, the estate is basically the same isn't it?) Thanks
  2. Re: Estate - Rear Number plate lights
    1840 Post(s)
    Water from a leaking rear wiper washer jet fitting.
  1. Please Help Estate - Rear Number plate lights
    By WesleyP in forum Golf MK6 - 2009 - 2013
    Last Post: 13-07-2018, 03:20 PM
  2. Number plate lights 2002 A4 Estate
    By monzaz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2016, 09:23 PM
  3. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  4. Number plate lights not working on B6 estate
    By paulni in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-01-2011, 12:32 PM
  5. Question Octavia Estate Rear Number Plate Light Bulbs
    By Leighhowlett in forum Octavia
    Last Post: 06-02-2009, 01:17 AM
