Thread: Estate - Rear Number plate lights
  1. Estate - Rear Number plate lights
    Jul 2007
    Co Durham
    Checking my rear number plate lights because one of them was out, I found that the plug on the end of the wiring harness, and the socket on the actual light fitting itself were badly corroded. As well as a new light fitting, I need a new plug on the end of a few inches of wire. It doers look like it may have been replaced before as there are soe crimped connectors about 3 incjhes up from the plug. If I get a standard light fitting, where can I get a plug on the end of a few inches of wire from? Alternatively there seems to be all sorts of LED lights available on Ebay. Are the number plate lights for an estate the same as for a hatchback? Can I get LED lights and just patch them into the existing harness? Thanks (Post on the Golf 5 5 pages as well, the estate is basically the same isn't it?) Thanks
  2. Re: Estate - Rear Number plate lights
    9891IAn Guest
    I had the same issue with one of my rear brake lights, didn't replace.
    Get white vinegar, mix with salt until dissolved, dangle the connector into the solution and swish about every couple of minutes, give it a once over with an old toothbrush.
    Then, dip the connector in a solution of water and baking soda to neutralize any reaction, dry off and put a little bit of neutral, conductive paste on the contacts.
    The light fitting itself, take a small flathead screwdriver to the contacts and scrape the corrosion off (I soaked a cotton bud in the vinegar mix first) and gave it a once over.
    Solved the issue.
    Or, get a can of contact cleaner, which I didn't have handy and was too hungover to go to Halfords
    As far replacing the light fittings, each I think has a mini harness with a small connector at one end for the fitting and a bigger one at the other that connects to the wiring loom in the boot.
    It's an easy swap for LED's or even replacement halogens but the LED's can throw faults.
    I think you should try cleaning the contacts first.
  1. Number plate lights 2002 A4 Estate
    By monzaz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2016, 09:23 PM
  2. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  3. Number plate lights not working on B6 estate
    By paulni in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-01-2011, 12:32 PM
  4. rear number plate lights
    By adamk in forum TT - 8N Forum - 1998 - 2006
    Last Post: 03-08-2009, 08:20 PM
  5. Question Octavia Estate Rear Number Plate Light Bulbs
    By Leighhowlett in forum Octavia
    Last Post: 06-02-2009, 01:17 AM
