Thread: TDi 1.9 Mk 5 Fuel Thermostatic Valve Location
  1. TDi 1.9 Mk 5 Fuel Thermostatic Valve Location
    Mar 2009
    Hello,
    Where is the thermostatic fuel valve located please.
    Is it in top of fuel filter or somewhere in the fuel line?
    Many thanks imk
  2. Re: TDi 1.9 Mk 5 Fuel Thermostatic Valve Location
    1836 Post(s)
    Shat thermostatic valve? Do you mean the fuel temperature sensor? This is in a small plastic adapter housing in the return fuel line from the tandem pump, these fail and also the wires snap as the sensor flaps around so much.
  3. Re: TDi 1.9 Mk 5 Fuel Thermostatic Valve Location
    Mar 2009
    Crasher many thanks for reply.
    Thanks but i know where the g81 temp sensor is.
    But in the system there is a Preheat valve.
    Basically fuel goes around a loop thus: Filter, High Pressure Pump, Injector rail, G81.
    When fuel is used by the injectors the the filter is topped up from the tank and the engine runs just fine.
    Problem is that the fuel in the loop ends up getting to hot, so the preheat valve opens to return fuel to the tank via the fuel cool under drivers seat.
    This basically maintains an optimal fuel temp and prevent waxing in the filter when fuel is cold.
    In the golf 4 and other VAG models of that time the PHV was a little valve on top of the fuel filter.
    So my question is where is it in the golf mk5?
    I think it is now inside the the top of the filter case.
    See diagram in this thread http://forums.tdiclub.com/showthread.php?t=349183
    Any ideas please?
  1. Question Egr valve location
    By Lewis Cox in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-11-2019, 01:14 PM
  2. PCV valve location???
    By pizzaboy150 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-07-2016, 03:51 PM
  3. N75 valve location
    By andyjerv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-04-2013, 09:49 PM
  4. PCV valve location
    By johnvw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-03-2011, 10:03 AM
  5. Question 1995 Golf VR6 fuel guage not working + fuel filter location
    By damo1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2008, 10:04 PM
