Thread: Audi allroad alloys
  1. Audi allroad alloys
    Jun 2018
    Bristol uk
    Please can someone help. Iíve just bought some used Audi wheels for my allroad. The garage fitted the rear wheels ok but said fronts are rubbing and I need spacers.
    What size? Do I need longer bolts as well?
    Sorry never changed wheels.
  2. Re: Audi allroad alloys
    Nov 2010
    Shetland & S.Tyneside
    103 Post(s)
    Assuming the new wheels are not too large diameter or width, you need to check the offset or ET number that will be in the wheel alloy casting, your new wheels are probably a lower offset than the original wheels. the difference between original ET and new ET will be spacer required. If you fit spacers only to the fronts they will stand out further, or have greater track, than the rears which will look weird and may affect handling. You can get Audi 5x112PCD spacer and bolt sets online once you know required thickness and PCD.
  1. Question 19'' Alloys for an Allroad
    By rodeoro in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-06-2015, 04:19 AM
  2. Replacing alloys for allroad
    By mcilwaine in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2014, 08:46 AM
  3. allroad alloys
    By overdraft in forum Wheels and Tyres
    Last Post: 13-07-2011, 11:11 PM
  4. aftermarket allroad alloys
    By markeyboy in forum Wheels and Tyres
    Last Post: 01-04-2010, 10:42 PM
  5. Allroad replacement alloys
    By stretch323 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-06-2009, 01:35 PM
