Thread: 2.0 tdi P2009 P2010 fault codes Inlet manifold flap
  1. 2.0 tdi P2009 P2010 fault codes Inlet manifold flap
    Hello forum and thanks for your help in the past.
    I have a 2009 A6 2.0 tdi Le Mans
    Much has been written about problems with the inlet manifold (swirl) flaps on this engine, and there are lots of kits out there to fix problems with the actuator mechanism and the motor itself.
    Most posts relate to the P2015 fault code, much less about P2009 or P2010.
    Nothing I have read explains how to find out if the problem lies with the motor (sometimes referred to as the solenoid) or the actuator mechanism. Is there any way to do this or is it simply a matter of refurbing the mechanism (about £70) first, then the motor if that fails to clear the error?
  2. Re: 2.0 tdi P2009 P2010 fault codes Inlet manifold flap
    Jul 2013
    76 Post(s)
    The first thing that I would do it remove the manifold and clean it as the fault maybe down to a flap not opening or closing fully due to dirt build up.
    The motor end cap can be removed (there is oil in the cap) to see the cogs, you would be looking for stripped teeth.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 2.0 tdi P2009 P2010 fault codes Inlet manifold flap
    Quote Originally Posted by dan2485 View Post
    Thank you for that Dan. I must admit I was hoping not to have to remove the manifold as I don't have the tools or software to re-prime the fuel lines, only a code reader and lots of spanners! I'll search the forum for advice about inlet manifold removal...
  4. Re: 2.0 tdi P2009 P2010 fault codes Inlet manifold flap
    Jun 2008
    7 Post(s)
    Have a look at the throttle body they get worn over time and there's a simple fix for the problem
    have a look at these videos
    https://www.google.com/url?sa=t&sour...elglUfQ_k4mViq
    The parts are easy to get from the bay if it is this causing the fault, you can test first with VCDS to see if the motor is moving, if it is not when set to test try pulling the actuator arm towards you if it moves you know this is one of the problems.
  1. Please Help Usual V157 inlet manifold flap motor fault
    By WellyBob66 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-02-2017, 04:30 PM
  2. Please Help Golf MK5 GT TDI Inlet Manifold Flap Fault Questions
    By liz87 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2014, 05:37 PM
  3. Intake Manifold Flap Fault Codes and Cleaning
    By aceofharts414 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-11-2010, 09:44 PM
  4. Please Help Inlet manifold flap and glow plugs.
    By Dee84 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-06-2010, 08:33 AM
  5. Inlet manifold flap
    By davegilsenan in forum Audi A3 - Archive Topics
    Last Post: 02-03-2009, 03:48 PM
