Thread: Need help please!! 2.7T cut out and won’t re-start
  1. Need help please!! 2.7T cut out and won’t re-start
    Feb 2014
    Leicestershire
    19 Post(s)
    Help please folks!
    My 2.7biturbo was working just great, I went round a roundabout with a hustle on and it kicked down (auto) and the engine died.
    I coasted to a stop put it in N and tried to re-start it and it just cranks and no fire.
    I checked fuse 28 for fuel pump and it is fine, and I read the engine speed while cranking via OBD in vag com and it rises quickly and stays cranking at 201rpm.
    What do you guys think I need to check next?
  2. Re: Need help please!! 2.7T cut out and won’t re-start
    Feb 2014
    Leicestershire
    19 Post(s)
    Been back out to the car, it’s parked about 100 m from the house ☹️
    I don’t see any rpm when cranking via the engine (G28) speed reading
    But no error codes on engine
  3. Re: Need help please!! 2.7T cut out and won’t re-start
    Feb 2014
    Leicestershire
    19 Post(s)
    Just a follow up...
    You know how these thing go, get it fixed and forget to update!
    Picked up a crank sensor form Parkers auto parts £18, not bad.
    The resistance over the one in the car was not the same, so I assume d it was bad and swapped it out.
    I also found a fuse gone, with the two changed, she was back to running normally same day
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Replies: 3
  3. Solved BLB engine too hard to start... but after starting the next start is normal..
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 11:51 AM
  4. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
  5. Won't start: faulty start valve?
    By Shaka1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 04:22 PM
