Thread: wheels
Results 1 to 10 of 11
  1. wheels
    Jun 2018
    doncaster
    good evening. i have dropped a clanger, bought some mk4 golf wheels for my mk6 , had them refurbed tried to fit them but no joy.
    any advice on how i can get them to fit please
    regards
    alan
    >golf
  2. Re: wheels
    1841 Post(s)
    You will need 5x100/M14 to 5x112/M14 spacer adapters and these are going to be at least 15mm thick so that thickness has to be subtracted from the ET (offset) of the wheel you are using and the total will become that wheels effective ET. A typical Golf 6 17 inch wheel is ET 54 so we need to know the specs of your new wheels. A typical Golf 4 17 inch wheel would be ET38 so if you subtract the thickness of a typical adapter you end up with ET23 which is way off but it all depends on what the new wheels specs are.
  3. Re: wheels
    Jun 2018
    doncaster
    Good Morning
    The wheels are 18"
    The tyre sizes on the wheels are 225/40z R18
    Hope this helps mate
    Regards
    Alan
  4. Re: wheels
    Aberdeen
    63 Post(s)
    Alan,
    You need the part number or look for the ET figure which should be stamped into the rear of the wheel spokes.
  5. Re: wheels
    Jun 2018
    doncaster
    It says pcd 5x100 5x112 yam 281
    And
    ET A452 18x7.5 j
    Regards
    Alan
  6. Re: wheels
    Jun 2018
    doncaster
    That is on the wheels that don't fit. Do you need the numbers on the golf mk6 as there just standard 16" alloy wheels mate
    Regards
    Alan
  7. Re: wheels
    1841 Post(s)
    Can you post some pics of the markings and close ups of the front and back of the hub?
  8. Re: wheels
    Jun 2018
    doncaster
    Sorry for late reply been really busy at work !!!
    Found some spacers but now the wheels stick out too far
    Do mk 4 golf discs fit on a mk 6 golf to change the stud pattern that way at all please ?
    Regards
    Alan
  9. Re: wheels
    Aberdeen
    63 Post(s)
    That won't help as the brakes have nothing to do with the wheel hub (apart from holes lining up). Cut your losses and sell them and get the correct size.
  10. Re: wheels
    1841 Post(s)
    Quote Originally Posted by alan1973 View Post
    Hi Found some spacers but now the wheels stick out too far
    That is what I was inferring and trying to explain in my first reply to you, the ET you have and the ET you need are wrong without spacers never mind with and you cannot reduce the ET, only increase it as you have, these wheels are not going to work.
  1. A6 BE FL - Wheels
    By Rower1978 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-03-2015, 12:15 AM
  2. Can I change 18 inch wheels for 17 inch wheels?
    By dln6376 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-03-2014, 09:49 AM
  3. Replies: 1
    Last Post: 11-03-2013, 08:20 PM
  4. New Wheels
    By Daz0925 in forum A8 - S8 - V8
    Last Post: 15-06-2012, 11:01 AM
  5. rs4 s5 wheels
    By ianmiles in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2009, 06:00 PM
