Thread: Handbrake warning light issue
  1. Handbrake warning light issue
    Mar 2014
    West Bromwich
    When driving if I turn my handbrake on it engages and then says there is an issue. It will not release either by presssing the button or trying to drive off. I have to restart the engine in order to release the handbrake.
    I have had both rear calipers fail due to the brake motor and know this is something different.
    I'm about to try disconnecting the battery but does anyone know what else it could be?
  2. Re: Handbrake warning light issue
    1840 Post(s)
    Get it code read, it will probably say control head issue which is VW speak for the button.....
  3. Re: Handbrake warning light issue
    Mar 2014
    West Bromwich
    Thanks.
    I did try my OBD reader but that didnt pick anything up. I'm assuming I have to take it to a garage?
    After doing a bit of reading apparently this can also happen if brake pads are low so I will inspect them before I pay for a diagnostic
  4. Re: Handbrake warning light issue
    1840 Post(s)
    Not on a 3C, there is no brake pad thickness feedback.
  5. Re: Handbrake warning light issue
    Mar 2014
    West Bromwich
    Cheers. Might just run the risk of ordering a new switch or nip to the scrap yard tomorrow and grab one
  6. Re: Handbrake warning light issue
    Mar 2014
    West Bromwich
    So turns out it's wasn't the switch
  7. Re: Handbrake warning light issue
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by dean1986 View Post
    Needs to be read by a VAG capable diagnostics tool as a majority of basic ODB readers cannot read the modular fault codes stored by VAG ECUs. A higher spec tool is required such as VCDS (VagCom), VAS or more professional hand held units normally in the £100 to £200 price bracket or above that are known to be able to query the required fault detail in VAG cars.
    Mad Mitch
    1 1 0
  1. Question Brake issues - handbrake; warning light.
    By alexl102 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-06-2017, 08:17 PM
  2. b5,5 handbrake warning light
    By jonathanbees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-08-2015, 02:47 PM
  3. Please Help Handbrake Warning Light Misbehaving
    By Tobez in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2013, 10:48 PM
  4. Handbrake warning light
    By trenchfoot Audi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2010, 12:55 AM
  5. Handbrake warning light
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-04-2008, 11:25 AM
