Thread: 1.9 tdi 2007 b6 - fault code 05522 and 00568 help.
  1. 1.9 tdi 2007 b6 - fault code 05522 and 00568 help.
    Jun 2018
    retford
    Hi everyone,
    Im trying to fix a fault on my sisters car. The vehicle has been throwing the fault code 00568 ( Turbocharger Boost Sensor (A) Circ High input ) intermitently.
    Tried changing boost sensor, seemed to reduce the frequency of the problem but did not fix it.
    It has more recently developed Fault code 05522 ( Altitude sensor signal/Charge air pressure sensor implausable ratio. )
    After clearing code, code comes back when ignition switched on, without starting engine. as apposed to 00568 which sets when driving / accelerating.
    have since tried another boost sensor just to be sure. I am thinking that its the wiring harness causing the problem but just thought I would post some info from live data / freeze frame data from my scanner and hope someone can confirm our suspicion of the wiring harness being the cause or if not offer some guidance how to find the cause.
    Ignition on engine off :
    Atmospheric pressure 999.60 mbar
    boost pressure(actual) 867.00
    mass air flow( actual ) 0.0
    Engine running idle:
    Atmospheric pressure : 999.60
    Boost pressure (actual) 999.60
    Mass air flow(actual) 235.0
    Some freeze frame data ( As my scanner displayed it )
    Fault Status 01
    Fault Priority 0
    Fault Frequency 03
    RPM 0/min
    Pressure 254.mbar
    Pressure -226mbar
    switch position 00011010
    Absolute Pressure 999.60mbar
    Absolute Pressure 148.60mbar
    Timing angle 4.0 ATDC
    ECU INFO ( I have included this as I thought someone might be able to tell me if it is up to date or been remapped? )
    VAG NUMBER 03g906021lr
    component R41,9LEDCG000SG9248
    soft coding 0000071
    WSC 000000
    IMP 0256
    Device 0001574
    Thanks in advance. I can post more live data if required.
  2. Re: 1.9 tdi 2007 b6 - fault code 05522 and 00568 help.
    1835 Post(s)
    What are you reading these codes with?
    there are known problems with the MAP/IAT sensor harness and there is a VW repair kit for the Golf 5 which can be used on any PQ35/PQ46 platform car.
  3. Re: 1.9 tdi 2007 b6 - fault code 05522 and 00568 help.
    Jun 2018
    retford
    Thanks for your reply.
    I used a Foxwell automaster pro to read the codes.
  4. Re: 1.9 tdi 2007 b6 - fault code 05522 and 00568 help.
    1835 Post(s)
    I may be wrong but I think it has misread the codes, this often happens with generic scanners.
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. A4 2.0 tdi 2007. power loss but no fault light or code!
    By skullion in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-06-2014, 09:14 PM
  3. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
