Thread: Manual gearbox oil
Results 1 to 10 of 16
  1. Manual gearbox oil
    Mar 2009
    Montenegro
    13 Post(s)
    Hello,
    I have a problem with clutch, last month had problem / juddering during taking off in first gear.
    I have bought LuK set:
    I am waiting now for pilot bearing (bearing inside the crankshaft) to arrive and start replacing the set.
    My questions are:
    - do I need to replace oil in my gearbox? If positive, please advise what kind of oil?
    - as I did not get any bolts with this LuK set do I need to buy any and if so which one and if you have part numbers
    The car is Audi A6 2.0 TDI, 2011, CAGB engine 100kw, manual gearbox code JWS, 217300km on clock.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  2. Re: Manual gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    Probably G 052 171
  3. Re: Manual gearbox oil
    Jul 2013
    76 Post(s)
    I have the same CAGB/JWS configuration and I did the a gearbox oil change about 2 services ago which was only 8 months ago for me.
    It does make a big difference on the smoothness of the box and gear changes.
    I used OEM oil as you only change this oil around every 100,00 miles.
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: Manual gearbox oil
    Mar 2009
    Montenegro
    13 Post(s)
    Thanks Dan and Gazwould,
    I am searching on net to find which oil is suitable. On service manual is written that oil does not need to be changed,it is for lifetime. I found on net that oil should comply to VAG standard G 052 911 A2. Oils which comply to that standard are either GL4 or GL5, or viscosity are 75W-90 or 75W-80, some full synthetic some semi synthetic. So, I am confused completely, the best thing is to buy original but it is very expensive. I called Skoda dealer and they asked for G 052 911 A2 37 Euro per liter (3 liters required for gearbox). I suppose that Audi dealer is more expensive and they will not tell me which oil is for my car unless I bought it at their shop.
  5. Re: Manual gearbox oil
    Jul 2013
    76 Post(s)
    get one of these as they make the job easier and cleaner.
    Laser 4385 Multi Purpose Mini Pump
    Dan
  6. Re: Manual gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    Quote Originally Posted by Novica View Post
    Easy..
    If it's G 052 911 .
    Fuchs Titan Sintofluid SAE 75W-80 .
  7. Re: Manual gearbox oil
    Jul 2013
    76 Post(s)
    The correct oil for the JWS gearbox is G 052 911 A2.
    Dan
  8. Re: Manual gearbox oil
    Mar 2009
    Montenegro
    13 Post(s)
    Thanks guys,
    I have spoke this morning with my indy and he told me that I need new bolts and that he is suprised that bolts did not arrived with new stuff.
    He said that we will check oil when we start job and if it is missing or oil is not so good (by color I suppose) we will change it.
  9. Re: Manual gearbox oil
    May 2012
    Everywhere
    308 Post(s)
    That's daft , just change it !
  10. Re: Manual gearbox oil
    Mar 2009
    Montenegro
    13 Post(s)
    Uh, I will be present all the time when we change clutch set and dualmass flywheel. I can insist to change oil. Only that, I am afraid when we change oil that will be no as good as original and if there will be some problem later on I will not be sure if it is caused by clutch, flywheel or gearbox oil.
  1. Question Manual gearbox oil spec for B8
    By Tonysco in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-01-2018, 10:38 AM
  2. Question Manual gearbox
    By Sparky_143 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-09-2013, 06:04 PM
  3. RIP To the Manual Gearbox?
    By theskyfox in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-10-2012, 05:02 PM
  4. Newbie Manual Gearbox Help Please
    By dulux72 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-11-2011, 11:40 PM
  5. Manual gearbox oil type
    By shabazmo in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2010, 08:39 PM
