Thread: Audi A3 1.9TDI PD105 Smoking! HELP!!
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Audi A3 1.9TDI PD105 Smoking! HELP!!
    Jan 2019
    Newquay
    I'm having the same problem on my A3 1.9 tdi 105. Does not smoke at all when cold. When cold runs rough sometimes and shakes a lot. When engine warms up, if left iddling for a minute or two you will see lots of blue smoke from behind. If you take it for a spin and floor it a couple of times, it clears up. I noticed when i was driving in really low revs like 1200rpm it started smoking too.
  2. Re: Audi A3 1.9TDI PD105 Smoking! HELP!!
    Jan 2018
    Sussex
    55 Post(s)
    Any fault codes dash lights?
    Could be injectors, DPF, sump ventilation.
  3. Re: Audi A3 1.9TDI PD105 Smoking! HELP!!
    Feb 2019
    Kent, Maidstone
    Hello mate.
    I would get VCDS on it and check live reading for the injector quantity and timing.
    Also Maf sensor not working corrently will mess up your air to fuel ratio.
    But get some live readings frist! If your injectors are worn then it might be causing that issue.
    AlexTheGrumpyOne For More Help
    www.youtube.com/c/alexthegrumpyone
  1. Question Where to get pd105 egr delete kit
    By Golf TD in forum 1.9TDi - Engine
    Last Post: 06-04-2017, 08:50 AM
  2. Question Smoking under acceleration (1.9Tdi)
    By OrangePanda in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-10-2014, 10:06 AM
  3. A4 1.9tdi smoking
    By Paddy27 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2009, 10:25 AM
  4. vw passat 1,9tdi pd smoking problem
    By audi_rs2 in forum Chat - Anything with wheels
    Last Post: 17-12-2008, 11:43 AM
  5. Passat 1.9TDI Engine Smoking
    By New2VW in forum Chat - Completely Off Topic
    Last Post: 18-07-2006, 04:45 PM
