This is the daft part , some got the old 77mm inferior hex drive key and some the revised 100mm , so your CAGA could have either!
The keyway bore in the balancer shaft end is still 6 machined grooves so splined like which means only the very tips of the hex drive key edges are in contact and none of the flats , daft
#2 .
The 77mm provides a miniscule 15mm contact length absolutely guaranteed to fail 50k-400k ( 80-150k most common ) the 100mm oem has 35mm of contact length and I've yet to hear of a failure .
Going from 15mm to 35mm in contact length is massive in engineering terms and there's no way an engineer would come up with that 15mm non hexagonal keyway unless the design brief was planned obsolescence ( it was designed to fail ) .
KMB further bullet proof on the 100mm oem by using an actual hexagonal chrome vanadium balancer shaft keyway insert , perfectly centered that provides 38- 40mm contact .
As for the low oil pressure light it's useless as it only operates above 2000 rpm and isn't sensitive enough anyway so that partially slipping drive key is giving a lower oil pressure for some time before it's total rounding failure , most delicate of all is the turbo .
You could get the car home , most idioticly limp it if a short distance , scratch their head , start it up in the morning , leave it idelling and no red stop oil pressure light and all the time the oil has drained into the sump overnight and it's not circulating...
