Thread: AMI help
  1. AMI help
    Aug 2010
    Prestatyn
    After reading through pages of AMI info, i am confused as ever.
    I bought a used A4 (B8 - 2009) last week and assumed it had an AMI input in the glove box. Unfortunately it didn't. In fact, it has nothing in the glove box part from a spare key holder !
    My MMI unit is a 2g high. It has a 6 cd changer in the dash and the control unit around the gears. The DVD sat nav lives in the boot.
    From searching around google/youtube/various form's i can't find this combination to gather info about what i need to add an AMI socket to the car.
    Do i need the full AMI unit and splitter to the back of the 6 cd changer in the dash, OR am i able to get a AMI cable, and cut a hole for it in the side of the glove box.
    Any help would be appreciated.
  2. Re: AMI help
    Oct 2012
    Estonia
    56 Post(s)
    you need "full" oem ami unit for mmi 2g or aftermarket ami kit!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+ Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency prog via cluster & gateway flash...
  3. Re: AMI help
    Oct 2015
    London, UK
    6 Post(s)
    What Gunnark said is spot on, they don't come with AMI - especially the early ones if it's 2G...
    I was looking into it when buying my A4 a few years ago and as it was a bit of a faff getting it retrofitted waited for one that already had it - if I remember correctly prices were about 450 for a full retrofit installed.
  4. Re: AMI help
    Aug 2010
    Prestatyn
    Thanks for the quick replies. At least i know which direction to go in now.
    Im guessing the unit will come with loom splitters, that just go in the rear of the in dash 6 cd changer ? Is it a case of plug and play at that point and the AMi will appear in the source menu automatically ?
    I have seen a few 'used' ami units on ebay, but there are a few different types of units. Most of them are advised for 3G not 2G. Will it matter, or is that just me being hope full.
  5. Re: AMI help
    Oct 2015
    London, UK
    6 Post(s)
    I'm pretty sure that the 2G and 3G system are totally different so not interchangeable.
    With 2G I think the AMI unit goes in the glove box and does connect to the back of the CD changer - but not 100% sure as I have a 2012 model which is a bit of a different setup - hopefully, someone with more knowledge can help.
  6. Re: AMI help
    Aug 2010
    Prestatyn
    I've been searching and i think for the MMI 2g high, its the 4E057785F AMI unit that may be required.
    But I've seen quiet a few AMI units for sale without the F at the end, just 4E057785.
    Does anyone know if these will be compatible ?
  7. Re: AMI help
    Oct 2012
    Estonia
    56 Post(s)
    Without suffix are probably early units from a8 and a6, they probably work, but I will not recommend those old units. So,
    4E0 035 785 B ,D or F.
