Thread: Front and Rear Washers not working
  1. Front and Rear Washers not working
    Mar 2013
    Farnham Surrey
    OK, so recent upgrade from my trusty 2002 TDI Sport Estate to a B7 2.0TDI 2014 Estate.
    Quite an impressive upgrade, but njo front or rear washers....no pump sound.
    I have googled and heard of column stalk or BCM possibly, but before returning to dealer want to check the fuses...any idea which fuse.
    I've googled a lot and I think it's fuse 40 in the front left dash fuseboard, but that says washer pump and rear wiper - my wiper works.
    Any help would be appreciated.
  2. Re: Front and Rear Washers not working
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    I would return to dealer if you have only just bought it as this would be considered an MOT fail.
  3. Re: Front and Rear Washers not working
    1840 Post(s)
    I have seen quite a few pumps fail and also the pump wire rub through on the point of a bumper bracket mounting bolt.
  4. Re: Front and Rear Washers not working
    Mar 2013
    Farnham Surrey
    It's going back, but just curious.....
  5. Re: Front and Rear Washers not working
    Mar 2013
    Farnham Surrey
    Many thanks Crasher, I'll let the dealer have a look.
  6. Re: Front and Rear Washers not working
    Mar 2013
    Farnham Surrey
    OK, so an update on this issue:
    Dealer had the car for 2 days, checked all the wiring, the pump etc etc, said it was looking like a "control unit" problem.
    Gave the "control unit" a re-start, and hey presto, everything working!
    Dealer was unsure of the cause or the issue, but decided not to charge me as a goodwill measure as they weren't sure of the fix - well done Martins of Farnham.
    I'm just hoping it's a permanent fix....
  1. washers and rear wiper not working
    By hubbo1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-09-2015, 09:21 AM
  2. Front and rear wipers and washers stopped to work
    By Bugajauzsi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2015, 11:40 AM
  3. Audi A3 front washers and rear wiper not working
    By phil miller in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-02-2015, 03:11 PM
  4. front washers not working
    By kim lowde in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-10-2013, 04:47 PM
  5. Please Help Rear washers not working - NOT the usual problem...
    By MrShades in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 01:48 PM
