Thread: Wheel bearing - circlips or not?!
  1. Wheel bearing - circlips or not?!
    Mar 2015
    middlesbrough, UK
    I am in the process of replacing a front wheel bearing on my 1998 A4 1.8T. The kit I got with the new wheel bearing has two circlips in it. The wheel bearing I've removed from the car didn't appear to have any circlips fitted, however, there is a groove at the rear of the hub that looks like it would take one. Any help would be much appreciated - I asked at my local Audi parts desk and got nowhere! I don't want to leave it out if it's needed (not that I can see what good it would do at the back of the hub - there's nowhere for the bearing to go), nor do I want to fit one and find the bearing won't go far enough in...
  2. Re: Wheel bearing - circlips or not?!
    1840 Post(s)
    Some setups have two circlip positions but yours will be one machined face that you push the bearing down onto and then a circlip you fit behind but to me you must always have a retention system both sides. The reason you have two clips is that bearing will have all sorts of applications, even as a washing machine drum bearing
  1. B8 A4 Wheel Bearing?
    By Garmy1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-01-2013, 05:19 PM
  2. Question Wheel Bearing/ Hub ???
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2010, 01:09 PM
  3. How To Change wheel bearing rear wheel
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 01:56 PM
  4. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  5. Wheel bearing???
    By HMIT in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2007, 06:06 PM
