Thread: 2012 Estate handbrake not smooth when operating
  1. 2012 Estate handbrake not smooth when operating
    Sep 2015
    Farnborough
    Just recently moved to VW and so far I’m impressed. Just a couple of issues I have with the car. The rear discs need replacing and the car has hill assist which works very well.
    Now when I pull the handbrake it feels very hard like it’s sticking but it holds the car. There isn’t a lot of meat on the pads and the discs are scored so I was wondering whether the operation on the handbrake will improve when I change the docs and pads.
    I can’t find a how to for the replacement so I’d be appreciated if there is something or similar car share the same system.
    Ryan
  2. Re: 2012 Estate handbrake not smooth when operating
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Is it Electric Park/Hand Brake or conventional cable? Calipers seize.
    Electric Park/Hand Brake do go faulty. You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: 2012 Estate handbrake not smooth when operating
    Sep 2015
    Farnborough
    Quote Originally Posted by Keithuk View Post
    It’s manual as far as I’m aware and the car has hill assist so I assume the brakes get used some more. They have calipers but I’m not sure if the rear pads have sensors on them for brake wear. Don’t have any messages as of yet and I also don’t have vagcom or vcds. Was looking to get something called obd11 but not much out there for that.
    Ryan
  4. Re: 2012 Estate handbrake not smooth when operating
    1840 Post(s)
    You may find the rear calipers are faulty and/or the carriers corroded and the Mexican built cars can be more prone to corrosion issues on the running gear.
  1. Replies: 4
    Last Post: 19-03-2018, 11:04 AM
  2. Sticking handbrake - Golf Mark V Estate
    By ChicksFan in forum Golf MK5 - 2004 - 2009
    Last Post: 30-01-2018, 07:55 PM
  3. Question Replacing reversing light on 2012 Audi A6 Avant estate
    By atapaz in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-03-2015, 12:03 PM
  4. Smooth it out!!
    By ss.raju-golf4 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2008, 01:12 PM
  5. audi 80 1.9tdi estate handbrake
    By eddiemax28 in forum 80 - 90
    Last Post: 12-03-2008, 02:29 AM
