Thread: Passat 1.8 B5 non turbo hesitation and kangarooing.
  1. Passat 1.8 B5 non turbo hesitation and kangarooing.
    May 2017
    Plymouth
    Hi all, 1.8 non turbo Passat with bad hesitation and kangarooing.
    Under soft or hard acceleration it bogs down and holds back around 2000 and 4000 rpm. Under it over those two points it pulls pretty well.
    It has just recently developed a bad kangarooing though also under hard acceleration. So bad your thrown back and forth in seat and need to let off throttle and accelerate softly to drive through it.
    Recently serviced, fitted new radiator, thermostat and coolant temp sender.
    It smells very rich. Fairly sure centre and rear section of exhaust are past it although not leaking.
    Would that cause these issues though??
    Has anyone got any idea or other suggestions ?
  2. Re: Passat 1.8 B5 non turbo hesitation and kangarooing.
    1840 Post(s)
    Check the fault codes and part of the problem could be a failed inlet manifold flap arm
  3. Re: Passat 1.8 B5 non turbo hesitation and kangarooing.
    May 2017
    Plymouth
    Think I’ve narrowed down to maf sensor .
  4. Re: Passat 1.8 B5 non turbo hesitation and kangarooing.
    1840 Post(s)
    Could be, it is getting on a bit but don’t be surprised if it does not help.
  5. Re: Passat 1.8 B5 non turbo hesitation and kangarooing.
    May 2017
    Plymouth
    Got a maf code come up. I unplugged it and took for a drive and no more kangarooing on default setting. So should be a replace and done job.
  6. Re: Passat 1.8 B5 non turbo hesitation and kangarooing.
    1840 Post(s)
    If I remember correctly the OE supplier was Hitachi.
  1. Please Help 1999 passat 1.8L turbo - "hesitation" when accelorating
    By Michelle86 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2010, 03:45 PM
  2. Please Help Passat TDI PD130 kangarooing at low revs low load
    By phil2401 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-09-2009, 06:14 PM
  3. Hesitation on hills with Passat TDI
    By yorky19640 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-09-2009, 10:41 AM
  4. V5 Passat missfire/hesitation
    By AntJ in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2009, 11:29 AM
  5. 97 1.8 Non Turbo Rough Idle / Hesitation
    By RobNorwich in forum Passat - Archive Topics
    Last Post: 29-03-2007, 07:03 PM
