Thread: Any fails with new stricter MOT for 3l diesel Quattro owners ?
Results 11 to 20 of 23
  1. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #11
    Aug 2012
    Birmingham
    Quote Originally Posted by lynalldiscovery View Post
    Yes std = standard ie no mods.
    Mates 2008 range rover passed recently, egrs blanked and chipped up, the tester went off the vin and it was the older 3.00 reading, it still passed with no effort and was below the tighter 1.50 so even if it was slightly later he would still have passed.
    Thanks LynallDiscovery , that’s kind of reassuring to hear.
  2. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #12
    Jul 2013
    Hertfordshire
    I had my 58 plate 3.0TDI MOT'd a couple of weeks ago - no problems.
    I was speaking to a guy who works at the local Bosch garage he said he'd only heard of one car that had fallen fault of the new regulations. He said to be absolutely certain just ensure the engine is nice and warm when it goes in for testing.
  3. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #13
    May 2012
    Everywhere
    308 Post(s)
    Not what I've been hearing in general , plenty of cars not making the lower default or vin value , and because of this some are finding they've a gutted dpf .
    Engine has to be hot and in good order , anything that can cause the enrichment of fueling... thermostat , maf , boost leaks , dirty air filter etc .
    Mine would of failed at it's usual test mean of 1.00 if it weren't for a new thermostat to get under 0.60 .
  4. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #14
    Aug 2012
    Birmingham
    Thanks Biglads , I will remember to make sure the engine is warm. A couple of years back I was told that a VCDS diagnosis had reported a couple of glow plugs failing . I asked about worst case scenario if I don’t replace them and they said it could mean on a cold morning that the car won’t start. I never had them replaced or any problem like that . But I s this something that could potentially impact on the emissions test ?
    The other thing is the car can go virtually unused for months at a time. I will check the tyre pressures and oil level, make sure the engine is warm. Is there anything else anyone would advise doing please ?
  5. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #15
    May 2012
    Everywhere
    308 Post(s)
    When you do use it how quick does it get up to temperature ?
  6. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #16
    Aug 2012
    Birmingham
    I tend to use it for long distance motorway driving which is pretty infrequent these days . I’d need to check how quickly the temp gets up.
  7. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #17
    Aug 2007
    Newport, Wales
    7 Post(s)
    Mine used to smoke like a chieftain tank... white smoke... sickly sweet over-fueling.
    I sent my injectors up to Diesel Bob in Lancashire - it turned out all six of them were leaking! (my car has covered 145k). Following replacement... she doesn't smoke at all; which is very reassuring considering the tighter MOT rules!
    The garage advised me to get rid of the car rather than doing the injectors (£1,500 including extraction & replacement) but I'm pleased I kept her... yes, she's starting to have more problems as the years go on but better the devil you know etc!
    Al
    [ My Cars: 2011 Caravelle SE TDI (140) LWB | 2015 L200 Barbarian 2.4 DI-D | 2015 Mini Cooper SD ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  8. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #18
    Jan 2010
    kent, england
    10 Post(s)
    Ours just passed on a cold engine with no
    problems - 2010 3.0TDI
  9. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #19
    Dec 2014
    Bedford
    42 Post(s)
    You could paint over the manufacture vin limit or scratch it off and there's nothing an mot test centre can do about it. If they cannot see it they have to apply the 2.50 default limit.
  10. Re: Any fails with new stricter MOT for 3l diesel Quattro owners ?
    #20
    Aug 2012
    Birmingham
    I’m happy to report , as the OP , that it passed the MOT today (at a Halfords Autocentre).
    I had both rear coil springs replaced in July last year. On the MOT today , they gave an amber advisory to renew both rear shock absorbers which they said had “light misting of oil”.
    Sorry for my ignorance , but can anyone explain what the difference is between a coil spring and a shock absorber, please ?
  1. Question Quattro owners - 3.0 TDI Quattro - tyre scrubbing on half to full lock - any ideas?
    By Thon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2012, 02:20 PM
  2. Common rail diesel owners. A quick question.
    By CMcK in forum Golf MK5 - 2004 - 2009
    Last Post: 22-12-2008, 01:53 PM
  3. Calling all 130 diesel owners
    By bryanp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2008, 11:57 AM
  4. golf turbo expert needed !!!! diesel owners please read
    By phil76 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-03-2008, 08:34 PM
  5. Diesel owners , Glow Plugs
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 22-10-2007, 04:22 PM
