Thread: BRD Camshaft Removal - Technical Help
  1. BRD Camshaft Removal - Technical Help
    Feb 2014
    United Kingdom
    Hi all,
    Just a very quick one. I have a BRD engine with a suspected Rocker Arm bearing failure (Roller bearing needles in the oil pump filter) looking at the head I can see the retaining plate for the camshafts splits at the cylinder head. But can the camshafts be removed without removing the head bolts? and the rocker arms?
  2. Re: BRD Camshaft Removal - Technical Help
    1841 Post(s)
    The rocker arm bolts go down into the head bolts which have an M8 hole in the middle for the rocker arm bolts N 105 811 01 which are one time only and must be replaced. If you don't have access to a T10262, I suggest you do not remove the cams.
  3. Re: BRD Camshaft Removal - Technical Help
    Feb 2014
    United Kingdom
    Damn
  1. Struggling to align camshaft sprokets holes with TDC Camshaft
    By Josana in forum Chat - Anything with wheels
    Last Post: 10-09-2022, 10:18 AM
  2. Audi A6 - C5 2.5 TDi Will Not Start After Camshaft Removal
    By Mogwato in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-07-2014, 11:27 PM
  3. Audi 80 TDi Camshaft Removal
    By Squealey in forum 80 - 90
    Last Post: 07-08-2008, 08:32 AM
  4. Technical help needed
    By timberman in forum Archive posts
    Last Post: 05-01-2005, 03:04 PM
