Thread: Knocking sound
  1. Knocking sound
    Feb 2018
    nenagh, ireland
    I purchased a B9 A4 (registered November 2015).
    It was all going well until the other night on locking the wheel to the left I heard a knocking sound (just one knock). If i park up and lock the wheels either direction i do not get any noise but on moving you can hear it. Has this happened to anybody else please?
  2. Re: Knocking sound
    Jun 2009
    South West
    Although I've not heard it on A4s I've driven (a sample size of two!) - it could be the brake pad moving slightly in the direction of the wheel rotation. Would only do it once per change of forward or reverse. Not sure this would explain your situation with the steering lock though?
    Previous: 1984 80 1.8 Sport, 1989 90 2.2. / 2009 A4 3.0TDi S Line Tiptronic.
    2016 A4 2.0 (252) TFSI S-Line Quat. S-Tronic
  3. Re: Knocking sound
    Aug 2017
    Australia
    Have you looked to see if the brake caliper is tight
    Mine came loose on a 2009 model just had to tighten the bolts up
  4. Re: Knocking sound
    Feb 2019
    London (SW), UK
    Could also be some play in the tie rods, which is a common issue and not too expensive to fix.
    I have the same thing in my S5 and usually only at low speeds and when turning.
    Replacement parts are quite cheap (40 for two rods from euro car parts) and is fairly straightforward to replace for a garage - just make sure they note the tracking position of the existing rods so that they can install to the same point.
  1. Important Knocking sound!
    By Noxidretep in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-08-2013, 08:38 PM
  2. Please Help Knocking sound
    By Passat07 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2012, 10:41 AM
  3. Knocking sound at idle
    By MAhearne in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2012, 11:29 AM
  4. Please Help Knocking sound when starting up
    By stokesy1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-07-2010, 01:47 AM
  5. Knocking sound from back
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-04-2007, 09:39 AM
