Thread: Cbab Turbo failure on 60 plate 113k miles
  1. Cbab Turbo failure on 60 plate 113k miles
    May 2018
    Inverness GB
    Hi Guys
    Recently suffered turbo failure which caused engine to rev uncontrollably(run on oil) . Would like to check for any engine damage by carrying out compression test. Any ideas what compression should be . AND has anyone else experienced this .Thanks in advance.
  2. Re: Cbab Turbo failure on 60 plate 113k miles
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    From my ageing memory, compression for a 2.0 common rail should be in the approximate range of 360 to 500 psi, the higher the better and no lower than around 300 psi. Maximum variance of around 75 psi between cylinders (the less variance the better unless they are all very low). Typically 400 psi is an ok reading, around 28 bar, but 500 is better, around 34 bar.
    Feel free anyone to revise my above estimations.
    Mad Mitch
  3. Re: Cbab Turbo failure on 60 plate 113k miles
    May 2018
    Inverness GB
    It doesn't look to good I'm only getting 20bar which is around 290psi. Just waiting for a new tester as I'm not confident in the one I used.
  1. Question Engine failure at 39k miles
    By Gad in forum A7 - S7
    Last Post: 04-11-2016, 02:08 AM
  2. Attention My 1.4 TSi 59 plate 35k miles full vwsh owned from new engine failure. How?
    By Alison Archell in forum Golf MK6 - 2009 - 2013
    Last Post: 16-08-2014, 02:47 AM
  3. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
