Thread: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
Results 11 to 20 of 28
  1. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    1842 Post(s)
    Not that I can think of, you have the miserable task ahead of removing and stripping the harness.
  2. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    Jul 2007
    Cheshire, or my A6
    To the OP - Did you find the break in the end?
    @Crasher - In your experience, have you any further thoughts where this wire could have broken?
    For info I have the same fault codes on a 2014 Yeti 2.0 TDI 4x4 (CFHC).
    Cheers,
    Paul
  3. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    1842 Post(s)
    16497 (P0113) - Intake Air Temp. Sensor (G42): Signal too High
    Could be anywhere but there is a connector called T4n on the gearbox so I would start with a continuity test on the yellow from pin 2 on the thrust (G31/G42 combined) sensor plug (T4g) to pin 2 at T4n (i.e. T4n2) and the brown from T4g/1 to T4n/1
  4. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    Jul 2007
    Cheshire, or my A6
    Thanks a lot for the info, Crasher! I will check out this connector on the gearbox. I had mistakenly followed a YouTube video that suggested the G31/G42 wiring is routed via the oval connector behind the passenger headlight - maybe it is on older cars. So now I am on the right track, thank you!
    I realise now I had mistakenly told you I have the same fault codes; so for the benefit of anyone reading in future I will clear this up. My fault code:
    Code:
    Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 QN    HW: 03L 907 309 AG
       Component: R4 2,0L EDC   H25 4787
       Revision: 42H25---    Serial number:                CVN: 30F9163D
       Coding: 001D0012042700080000
       Shop #: WSC 33361 790 00085
       ASAM Dataset: EV_ECM20TDI01103L906018QN 003004
       ROD: EV_ECM20TDI01103L906018QN.rod
       VCID: 06559706D8A04A6BD1E-8052
       VINID: 91D49D50715C0D518004718210A182BE74
    1 Fault Found:
    5169 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [167] - Signal too High
              MIL ON - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 144642 km
                        Date: 2022.11.21
                        Time: 21:59:35
                        Engine RPM: 1528.50 /min
                        Normed load value: 48.6 %
                        Vehicle speed: 12 km/h
                        Coolant temperature: 64 °C
                        Intake air temperature: 23 °C
                        Ambient air pressure: 970 mbar
                        Voltage terminal 30: 14.140 V
                        Unlearning counter according OBD: 40
                        Charge air pressure: actual value: 3000 hPa
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Readiness: 0 0 0 0 1
    So in truth I will be checking for continuity on the pin 4 violet wire from T4g to T4n as a first step.
  5. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    Mar 2010
    Derry ireland
    60 Post(s)
    can you post up your year & engine code
  6. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    1842 Post(s)
    2014 cfch
  7. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    #17
    Jul 2007
    Cheshire, or my A6
    All fixed
    The violet wire had broken apart cleanly right by the gearbox connection. Fixed for now with a jumper wire...
    @Crasher - big thanks for your help, saved me hours! I don't suppose you'd know if VW sell a repair wire/pigtail for this "t4n" connector? I'd love to get a male & female pair to do a nice tidy job of this.
  8. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    #18
    1842 Post(s)
    I think one side of the plug is 1K0 973 804 which would take double ended repair wire 000 979 041 EA (Gold plated, good idea) and the other half 1J0 973 704 (or it may be the new number 8K0 973 704) and repair wire 000 979 038 EA, drop the A if you opt for non Gold plated.
  9. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    #19
    Jul 2007
    Cheshire, or my A6
    Amazing, thanks for this Crasher. Will head over to TPS later.
    Unfortunately the fruits of my labour (fixing the wiring, DSG service & Haldex service) was a new problem. After cleaning the gunge from the Gen 5 Haldex strainer, I ran the pump adaptation in VCDS (as there was a fault code stored for the pump not working). This appeared to get stuck, so I interrupted the adaptation after some minutes. Now I have no comms to address 22 Haldex controller. I will check the wiring first. Any thoughts what the problem might be would be greatly appreciated.
    Code:
    Monday,28,November,2022,22:20:49:30325
    VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
    Data version: 20221026 DS344.0
    www.Ross-Tech.com
    VIN: TMBMD75L3E6017624   License Plate: GJ14JDO
    Mileage: 144640km-89875mi   Repair Order:
    Chassis Type: 5L-SK35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4F 52 55 56 62
              72 77
    VIN: TMBMD75L3E6017624   Mileage: 144640km-89875miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    No fault code found.
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 016 E    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4006
       Revision: 05652104    Serial number: 00001311220256
       Coding: 0000020
       VCID: 1675C7468480FAEB21E-8042
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 933F400E09230101C91102E6901D808AA1000020
       VCID: 7EA5FFE680F012AB99E-802A
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 92
                        Mileage: 144647 km
                        Time Indication: 0
                        Date: 2017.04.20
                        Time: 22:14:10
                 Freeze Frame:
                        Count: 0
                        Count: 12
                        Count: 12800
                        Count: 8202
                        Count: 51712
                        Count: 0
                        Count: 0
                        Count: 256
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
       Component: Climatronic   H19 0709
       Revision: 00001009
       Coding: 0010000002
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 7CA1F5EE966C00BBB7A-8028
    Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
       Part No SW: 1K0 937 087 AK    HW: 1K0 937 087 AK
       Component: BCM PQ35  H   112 0771
       Revision: AF112771
       Coding: 48000ABBE05BF1C0400800C0110089E44B7000AE726D8760808140040040
       VCID: 7AADF3F69CD83E8BA56-802E
       Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
       Component: SK356  26  0610
       Coding: 00F7B5
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 211213 05  54  0403
       Coding: 062BED
       Subsystem 3 - Part No: 1K8 951 171
       Component: DWA-Sensor 00  001 0104
       Subsystem 4 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
       Part No SW: 5J0 919 475 B    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0010
       Revision: --H11---    Serial number: 32931335201432
       Coding: 108107
       ASAM Dataset: EV_EPHVA14SKxxx0000 002001
       ROD: EV_EPHVA14SKxxx0000_002.rod
       VCID: 34311DCEFEBC08FB3FA-8060
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Component: AirbagVW10    014 0613
       Serial number: 003G5RASHNRR
       Coding: 00004E42
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313F14DA01AE3DD354C-8064
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Fahr.V  H02 ----
       Serial number: 3572MSME1B473B40ZZZY
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Beif.V  H02 ----
       Serial number: 3582MSME09422D41ZZZT
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Fahr.H  H02 ----
       Serial number: 3516KSME0B09372AZZZV
       Passenger side rear thorax airbag crash sensor:
       Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Beif.H  H02 ----
       Serial number: 3526KSME4E783B2AZZZ6
    Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
       Part No SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
       Component: LENKS.MODUL   016 0140
       Revision: FF010042    Serial number: 20131218201351
       Coding: 1882140000
       ASAM Dataset: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 71BFD4DAC12E7DD314C-8024
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
       Component: E221__MFL-PR6  H04 0130
       Coding: 820000
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5L0 920 940 M    HW: 5L0 920 940 M
       Component: KOMBI         H06 0811
       Serial number: 00000000000000
       Coding: 420E00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
       VCID: 363527C6E8C01AEB01E-8062
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 151213F1001477
       Coding: 356303
       VCID: 7BA3F6F293E20783BE0-802E
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 92
                        Mileage: 144647 km
                        Time Indication: 0
                        Date: 2017.04.20
                        Time: 22:14:10
    Address 22: AWD
    Cannot be reached
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H06 0811
       Coding: 000000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
       ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
       VCID: 6A8DC3B6ECF88E0B556-803E
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
       Component: TSG FA        H03 0553
       Revision:             Serial number: 0000085094141
       Coding: 01150220D001231004
       VCID: 46D5570698A08A6B91E-8012
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 71     3501
       Revision: 00H22000
       VCID: 392F2CFAD55EF593ECC-806C
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1642
       Coding: 050B0500
       VCID: 6FBBD2A2D79A6B23028-803A
       Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Serial number: 0123456789ABCDEFGHIJ
       Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
       Component: TSG BF        H03 0553
       Revision:             Serial number: 0000085204637
       Coding: 01150020D001231004
       VCID: 45D7500AA5A68173984-8010
    Address 55: Headlight Range (J745)       Labels:. 5M0-907-357-V3.clb
       Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0111
       Revision: --------    Serial number: --------------
       Coding: 035E00003F000000
       ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 372B2AC2EFCAE3E31A8-8062
       Left_headlamp_power_output_stage:
       Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Right_headlamp_power_output_stage:
       Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 1Z0 035 156 N    HW: 1Z0 035 156 N
       Component: BOLERO        003 0013
       Revision: -----13S    Serial number: SKZ4Z3N1148869
       Coding: 1D0004000001
       VCID: 3D2738EACD76C9B3C04-8068
    1 Fault Found:
    00856 - Radio Antenna
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 92
                        Mileage: 144646 km
                        Time Indication: 0
                        Date: 2017.04.20
                        Time: 21:57:24
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
       Part No SW: 7N0 959 795 E    HW: 7N0 959 795 E
       Component: TSG HL        H03 0553
       Revision:             Serial number: 0000085247248
       Coding: 010000200001531004
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
       Component: TSG HR        H03 0553
       Revision:             Serial number: 0000085249247
    Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007665602359
       Coding: 0200000000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A2D33F6DCD8FE8BE56-806E
    End----------(Elapsed Time: 01:32, VBatt start/end: 14.0V/14.1V)-----------
  10. Re: P0113 CAYC MK6 Golf Intake Air Temp (have VW ordered me the right part?)
    #20
    1842 Post(s)
    We have had that a few times now on the Gen 5 (and Gen 4), ECU failure caused by the pump screen being blocked and it fries the ECU. I heard of one case where a new ECU failed because the pump was still taking a high current and Audi (in this case an S3) refused warranty as they said the pump should be changed with the ECU which is suggested on the parts system. Obviously check fuse Sc22 (dash side) and that there is power at pin 1 of the Haldex plug on the black/blue across to the earth at pin 2 brown.
  1. Please Help Golf MK6 ANNOYING CODES P0113 P0238
    By Golfmk6code in forum Golf MK6 - 2009 - 2013
    Last Post: 31-05-2018, 08:13 AM
  2. OBD CODE P0113 - Intake Air Temp circuit high input - A3 BKC 1.9TDi Sport
    By bennoA3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-06-2016, 03:36 PM
  3. Question Air intake temp sensor golf tdi
    By phil miller in forum Golf MK5 - 2004 - 2009
    Last Post: 11-12-2010, 09:02 PM
  4. Replies: 2
    Last Post: 08-10-2010, 01:27 PM
  5. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
