Thread: Caddy ecofuel - No contact, no crank
  1. Caddy ecofuel - No contact, no crank
    May 2018
    Sweden
    My caddy suddenly stopped working,
    the cluster show nothing at all when key turned, only the middle display light up when unlocking car
    Lights, radio and central locking working
    No crank, no communication with ECU
    The oil lamp was on before this happend but the oil level is good.
    I noticed that one relay in engine bay do not click (it clicks on a functioning car, so i replaced but still nothing)
    Battery brand new Varta
    Worked good before
    Replaced coils on tube, and fitted new wire on one tank 15 min before (fuse all okey)
    Caddy 2.0 Ecofuel 2008
  2. Re: Caddy ecofuel - No contact, no crank
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    check ignition switch
  3. Re: Caddy ecofuel - No contact, no crank
    May 2018
    Sweden
    Thanks for reply. I hace dissasembled the switch, what should i be looking for exactly? I turn the ignition with screwdriver (with kkey in the lock) and when turning to ignition, i get a relay sound on relay #460 under the steering wheel. I also get the spring load when on ignition.
  4. Re: Caddy ecofuel - No contact, no crank
    May 2018
    Sweden
    Problem solved
    It was one of the #460 relays (left). Replaced and now car works fine.
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Question Noise from 1.4 tsi ecofuel engine
    By ecopassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2014, 02:54 PM
  3. Question caddy sdi crank sensor fault permanent
    By sniper1212 in forum The Commercial Range
    Last Post: 30-01-2012, 02:30 PM
  4. Replies: 0
    Last Post: 28-08-2008, 05:10 PM
  5. The Caddy Topos Sail Design Concept – A Caddy With A Boat Deck!
