Thread: Air con question
  1. Air con question 2014 A6 2.0tdi s-line ultra
    Mar 2018
    Fermanagh
    Hi, I recently noticed that there was no cold air coming from my vents (I’ve only had the car for a few weeks so far), I push the A/C button and the light comes on but doesn’t stay on, I plugged in my laptop with the Delphi diagnostics software and I’m getting told that the A/C pressure sensor is open circuit permanent and also the humidity sensor in the air inlet vent is open circuit permanent, I am going to order these 2 sensors and fit them but has anyone had the same issues? I’m hoping the new sensors will fix my problem.
    I’m guessing the A/C sensor is behind the bumper near the condenser??
    Also forgot to mention that I checked the fuses, the fuses on the passenger side fuse box where ok, but when I checked the drivers side there was a 5amp and 10amp fuse missing, going by the Audi manual these fuses should be there so I fitted them but no joy, still got the same fault codes
  2. Re: Air con question
    Mar 2014
    Edinburgh
    235 Post(s)
    Had the pressure sensor problem before on older VAG cars. Seems quite common and parts were readily available. If I remember right the on the golf it was a bumper off job to get to the sensor.
  3. Re: Air con question
    Mar 2018
    Fermanagh
    Don’t mind taking the bumper off as I also have an open circuit on my front parking sensors that needs investigated, 2 birds with one stone I suppose
  1. Question RCD 510 Can Bus Question
    By EvilSmoothie in forum In Car Entertainment
    Last Post: 22-09-2016, 07:32 PM
  2. heater question and antifreeze question
    By tick73 in forum Golf MK2 - 1984 - 1992
    Last Post: 20-01-2014, 02:30 PM
  3. MMI question
    By Mark996 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 28-06-2013, 03:02 PM
  4. Answer A Question & Ask Any Question?
    Last Post: 23-11-2011, 01:51 PM
  5. A3 3.2 Quattro s-tronic question and exhaust question
    By audia3.2 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-09-2009, 05:09 PM
