Thread: 1.4tsi ticking noise after timing chain replaced
  1. 1.4tsi ticking noise after timing chain replaced
    May 2018
    S wales
    Hi all, new member hoping someone can help, I have just replaced the timing chain and tensioner on my sons golf 1.4tsi 2010. I checked the timing when all built back up but when I start up there is a metallic ticking noise a bit like a diesel sound can anybody help with what could be causing it, many thanks
  2. Re: 1.4tsi ticking noise after timing chain replaced
    1840 Post(s)
    Did you use the crank locking pin, cam locking plate and set number 1 piston at TDC using a dial gauge?
  3. Re: 1.4tsi ticking noise after timing chain replaced
    May 2018
    S wales
    Hi crasher thanks for your reply, yes I set it to Tdc using Dti and inserted the camshaft setting tool, I wasn’t aware of a crankshaft locking tool tho, where does this go to lock the crankshaft?
    I think I have found the problem, while looking in the box where I stored all the parts I found a small tube, I wondered where it came from as I did not take it off, however after trawling through pages of forums and drawings I finally found that it goes through the centre of the vvt sprocket. It must have fallen out without me noticing. So another strip down to replace it. I am interested to hear how to lock the crankshaft tho if you could tell me, cheers
  4. Re: 1.4tsi ticking noise after timing chain replaced
    1840 Post(s)
    Some have a bolt in the back of the block behind number 1’s first crank web which you take out and bolt in a locking pin. Yes leaving out the sleeve 03C 103 825 A (£3.24) would prevent the VVT unit from working.
  5. Re: 1.4tsi ticking noise after timing chain replaced
    May 2018
    S wales
    Thank you again crasher, all done cheers for your help
  1. Please Help 1.2 (AQZ) Not running after timing chain replaced WHY???
    By d4rr4gh in forum Polo - Derby - Lupo - Fox
    Last Post: 16-10-2018, 08:50 PM
  2. Timing chain noise 2.7 v6 tdi
    By taximeistergolf in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-06-2018, 12:23 AM
  3. 1.4tsi timing chain?
    By Bigben86 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-08-2015, 04:25 PM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
