Thread: Touareg 2.5 tdi any good?
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Re: Touareg 2.5 tdi any good?
    #21
    Apr 2015
    Bedford
    6 Post(s)
    Quote Originally Posted by Gnits View Post
    The centre bearing usually fails at around 70-80.000 miles max, so, on those car it has been most likely already replaced. You should ask the previous owner/seller when this was done, and from there you could estimate when you can expect to fail it next. (It also helps if you don't drive the car in the mud, and if you remove the old grease and re-apply some new to the bearing every once in a while.)
    Also, the forum board seems to mess up the link in my previous post for some reason. So, here it is, in plain text: VW Touareg Drive Shaft
    Thanks for link
    Sent from my SM-G950F using Tapatalk
  2. Re: Touareg 2.5 tdi any good?
    #22
    Apr 2015
    Bedford
    6 Post(s)
    I had a bit of drive in the 3.0 today, pulls nice better then 2.5, needed new pads at least, to me should had disk replaced is well due to large lip, found that small rod from swirl motor to flaps in center arm rest, so sort of alarm bells rung, oil leak but couldn't see where is coming from it was on left front as you sit in car, anyway he wouldn't budge on price from 5.5k with 125kon clock so I walk away from it.
    Just a question on test drive everytime the car hit pot hole or whent over uneven surface just didn't feel right like it swayed, but no rattles or anything is this normal to them?
  3. Re: Touareg 2.5 tdi any good?
    #23
    Apr 2017
    Neverland
    7 Post(s)
    Quote Originally Posted by ade555 View Post
    If it has standard (spring) suspension, then most likely the spring has worn out, or the oil has escaped from the shock absorber. If it has air suspension, there might be something more serious at play with the frame or undercarriage. Have you looked for uneven wear on the tires? If it has air suspension, have you tried changing the ride height?
  4. Re: Touareg 2.5 tdi any good?
    #24
    Apr 2015
    Bedford
    6 Post(s)
    If it has standard (spring) suspension, then most likely the spring has worn out, or the oil has escaped from the shock absorber. If it has air suspension, there might be something more serious at play with the frame or undercarriage. Have you looked for uneven wear on the tires? If it has air suspension, have you tried changing the ride level?
    Std suspension, you might be right with worn shocks, had similar feeling on one of my other cars long time ago and found rear shocks was blown.
    Feel better that I walk away now. Looks like that car could have been money pit from start.
  1. Today is a very good day and I'm in a good mood
    By AGlincLix in forum Chat - Completely Off Topic
    Last Post: 15-05-2013, 10:05 AM
  2. Good news for buyers of Volkswagen Touareg and CC Models
    Last Post: 26-01-2013, 07:37 PM
  3. Good news for buyers of Volkswagen Touareg and CC Models
