Thread: passat turbo vanes help required.
  1. passat turbo vanes help required.
    May 2018
    manchester
    hi all, it seems i have the sticky turbo vanes as my car goes into limp mode on the motorway under load and spluttering at high revs, i have done alot of reading and was after some help really, ideally would like to have it cleaned as its helped alot of people.. is there anywhere near manchester who could clean the turbo vanes for me as i dont have the slightest clue how to do it myself lol.. thanks
  2. Re: passat turbo vanes help required.
    Nov 2010
    Shetland & S.Tyneside
    99 Post(s)
    get it scanned to confirm what is going on before convincing yourself it is the VNT at fault.
  3. Re: passat turbo vanes help required.
    May 2018
    manchester
    its been on a machine and the mechanic said it was overboost issue and it needs a new turbo..
  4. Re: passat turbo vanes help required.
    Nov 2010
    99 Post(s)
    only effective long term solution seems to be a replacement turbo, some folks do the mr muscle thing, I doubt you'd find any garage willing to do a 'clean', likely be too many comebacks to make it worth their bother.
  5. Re: passat turbo vanes help required.
    Jan 2012
    Rustington, West Sussex UK
    22 Post(s)
    Quote Originally Posted by Rob69 View Post
    Not hard to DIY if you have some mechanical knowledge. Hardest part is taking it off which is a bit of a pain as it involves undoing what might be tight manifold nuts, releasing the oil feed and DPF / exhaust coupling (loosening their mounting bolts to do so) and a few other bits. Splitting the snail shells (one will be cast as part of your exhaust manifold) away from the centre cartridge is fairly easy by first unclipping the actuator lever and removing the actuator, then it's just unbolt the sections and separate the parts. Clean the exhaust side which is the bit that sticks to within an inch of its life with brake cleaner and an emery cloth. A bit of copper ease on the ring plate edges will keep it moving as long as you clean the recess at the lip of the exhaust shell thoroughly. Reassembly is the reverse process with new exhaust manifold and turbo coupling gaskets and manifold nuts. Loads of how to videos on YT but like you said it's getting someone to do it if you're not mechanically adventurous. Recon turbo is around 250 to 350 and new one around twice that plus the labour and VAT to boot. My original turbo did 103k on my car and has done a further 85k on another car after I cleaned it (I upgraded to a new better Garrett version on offer at 550 and sold the cleaned up one for 300 at the time).
    OP: Put a thick glove on, find the bottom of the actuating leaver (dead centre of the turbo) and vigorously work it up and down a couple of dozen times (it only moves a couple of centimetres max). This should dislodge some of the carbon deposits and free it for a little while.
    Mad Mitch
  6. Re: passat turbo vanes help required.
    May 2018
    manchester
    thanks for the reply mate. yeh to be very honest i have very little mechanical knowledge lol so dont fancy trying it myself.. yeh i understand what your saying but i thought there must be a mechanic or someone who has done this before round manchester that can do mine for me.. anyway still hoping some1 pops up lol.
  7. Re: passat turbo vanes help required.
    May 2012
    Somerset
    193 Post(s)
    Buy a B5.5 , more reliable and only 2 Allen key bolts and two nuts at the top of the engine to Mr Muscle the turbo .
  1. Turbo vanes gone, what now?
    By Luffers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2014, 06:50 PM
  2. stick turbo vanes
    By boidy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2009, 09:51 PM
  3. sticky turbo vanes
    By bigplum in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2008, 11:39 PM
  4. turbo vanes.
    By davetdiredi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2008, 07:39 PM
  5. sticking vanes on my turbo?
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-10-2007, 07:21 PM
