Good Morning
This is my first post and I'm also new to VCDS, which probably doesn't help...
I have the scan below. All fuses (under the steering wheel) are OK as are the relays.
There was a broken link on the battery, (now replaced by a new one) and it was caused by a chaffing problem.
Most of the dashboard lights are constantly lit. The electric windows don't operate. The speedo is not working also.....
HELP.
Sunday,20,May,2018,14:43:02:55942
VCDS -- Windows Based VAG/VAS Emulator Running on Windows7 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ6RZCU006144 License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU006144 Mileage: 118850km-73849miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P906 021 AHW: 03P 907 425 A
Component: R31.2l TDIH06 9979
Revision:11002001Serial number:
Coding:00114010000500080000
Shop #: WSC31414 790 50316
ASAM Dataset:EV_ECM12TDI03103P906021A 001024
ROD:EV_ECM12TDI03103P906021.rod
VCID:26445164593D8B747D-8072
3 Faults Found:
13971 - No Communication with ABS Brake Control Module
U0121 00[191] - -
[Newfeature! Extended UDS fault detail is only supported by current gen.interfaces]
MIL ON -Confirmed - Not Tested Since Memory Clear
FreezeFrame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 118857 km
Date: 2018.05.20
Time: 16:17:02
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 5 km/h
Coolant temperature: 9 °C
Intake air temperature: 15 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.468 V
Unlearning counter according OBD: 1
OBD Driver demand indicated torque: 0 %
Communication status of data bus 1: CAN Bus ON
Cruise Control System (CCS): status: 00000000
Terminal 15 status: On
Gear Ratio: 0
Sensor for engine block temperature: raw value: 9 °C
13983 - No Communication with ABS Brake Control Module
U0121 00[191] - -
FreezeFrame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 118857 km
Date: 2018.05.20
Time: 16:17:02
Gear Ratio: 0
13972 - No Communication with ABS Brake Control Module
U0121 00[063] - -
Confirmed- Not Tested Since Memory Clear
FreezeFrame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 118857 km
Date: 2018.05.20
Time: 16:17:02
Gear Ratio: 0
Sensor for engine blocktemperature: raw value: 9 °C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0820 045 GHW: 6R0 820 045 G
Component: ManAC02 0101
Revision: 0002S02
VCID:326CBD346DF5E7D4E1-8066
1 Fault Found:
01316 - ABS Control Module
004 -No Signal/Communication
FreezeFrame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 16:19:27
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0937 087 KHW: 6R0 937 087
Component: BCMPQ25 H+4H46 0251
Revision:BF046001Serial number: 0434 191111733
Coding:24B02BBF08A10000003008002D2B0CD00000410F600 60000200000000000
Shop #: WSC31414 790 31414
VCID:4586F6E8CC7B606C54-8010
Subsystem 1 -Part No SW: 6R0 959 802 ABHW: 6R0 959802 ABLabels: 6R0-959-802.CLB
Component:J386__TSG_FT008 1611
Serial number:KU0KU010061100011341
Coding: 18BC30
Subsystem 2 -Part No SW: 6R0 959 811 GHW: 6R0 959811 G
Component:J388__TSG_HL008 1611
Serial number:KU0KU018061100011602
Coding: 08BC32
Subsystem 3 -Part No SW: 6R0 959 812 GHW: 6R0 959812 G
Component:J389__TSG_HR008 1611
Serial number:KU0KU020061100011920
Coding: 08BC32
6 Faults Found:
03435 - Terminal 30 for Interior Light and Parking Light
011 -Open Circuit - Intermittent
FreezeFrame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 17:26:53
03396 - Supply voltage terminal 30 for central locking
FreezeFrame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 17:26:53
00920 - Heated Outside Mirrors; Driver Side (Z4) /Passenger Side (Z5)
011 - Open Circuit - Intermittent
FreezeFrame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 17:26:54
00538 - Reference Voltage
FreezeFrame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 17:41:19
01332 - Door Control Module; Passenger Side (J387)
FreezeFrame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.08
Time: 00:00:04
03591 - Control Circuit for Horn
FreezeFrame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 118857 km
Time Indication: 0
Date: 2012.10.10
Time: 17:26:54
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0959 655 KHW: 6R0 959 655 K
Component:VW10Airbag027 H09 0020
Revision:--------Serial number: 003GX00R0EHO
Coding: 003237
ASAM Dataset:EV_AirbaVW10BPAVW250 A01001
ROD:EV_AirbaVW10BPAVW250.rod
VCID:4A9CC5D4ED658F14B9-801E
Crash sensor forside airbag: driver side:
Serial number:3575HRB40550H4DKC9C4
Crash sensor forside airbag: front passenger side:
Serial number:3585HRB405P0H4DK91QS
Crash sensor forside airbag: rear: driver side:
Serial number:3515RRB40530KSEGAG4R
Crash sensor forside airbag: rear: passenger side:
Serial number:3525RRB40570JNPMCOU-
2 Faults Found:
12854016 - Databus
U1122 00[009] - Implausible Message
Confirmed- Tested Since Memory Clear
FreezeFrame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 86
Mileage: 118857 km
Date: 2018.05.18
Time: 00:07:46
12656896 - Databus
FreezeFrame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 118857 km
Date: 2018.05.18
Time: 00:07:49
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6R0920 961 HHW: 6R0 920 961 H
Component:KOMBIH03 0505
Serial number:00000000000000
Coding: 440A01
ASAM Dataset:EV_Kombi_UDS_VDD_RM09 A04113
ROD:EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID:3B729010B2BF269C32-806E
1 Fault Found:
12656896 - Function Restricted due to Missing Message(s)
U1111 00[009] - -
FreezeFrame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 118857 km
Date: 2018.05.18
Time: 00:01:01
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0909 901HW: 6R0 937 087
Component:GW-K-CAN TP20 H46 0251
Revision:BF046001
Coding: 002300
VCID:70E8773CA37995C4D7-8024
No fault code found.
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0953 234HW: 5K0 953 234
Component:IMMOH03 0505
Serialnumber:
Coding: 000000
Shop #: WSC00000 000 00000
ASAM Dataset:EV_Immo_UDS_VDD_RM09 A03009
ROD:EV_Immo_UDS_VDD_RM09.rod
VCID:6ADC65548DA56F1499-803E
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423156 B
Component:LenkhilfeTRWV277
Coding: 11230
Shop #: WSC31414
VCID:2F6AB440EAC7CA3C8E-807A
2 Faults Found:
00778 - Steering Angle Sensor (G85)
49-00 -No Communications
01317 - Control Module in Instrument Cluster (J285)
79-00 -Please Check Fault Codes
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5M0035 186 JHW: 5M0 035 186 J
Component: RadioRCD310032 0079
Revision:01000001Serial number: VWZ1Z2L3429403
Coding:01000400020001
VCID:3362B83092EFEEDCEA-8066
End-------------------------(Elapsed Time:02:46)--------------------------
