Thread: Golf Mkv Exhaust Pressure Sensor G450
  1. Golf Mkv Exhaust Pressure Sensor G450
    Sep 2017
    Plymouth UK
    Hi All,
    Hoping someone can advise...
    I came back from a shot journey (100 mile round trip) last night and the Engine Management Light came on when I stopped for fuel and restarted, when I got home I connected VCDS which revealed the faults listed below, I cleared these faults and the following day took it for a 70 mph drive in 4th for a while, hoping to initiate a regenerate of the DPF should it need it, I did about 30 miles in total (about 10 in 4th) and went for a walk, when I returned an hour or so later and started the car the Engine Management Light came on, going by the VCDS log below I'm hoping all I have to do is replace the "Exhaust Pressure Sensor" (EPS), what do you think? could it be that the other faults are being caused by the EPS malfunction?
    Also, If I do replace the EPS, does anyone know how to set it up in VCDS?
    Thanks in anticipation
    001137 - Exhaust Pressure Sensor 1 (G450)
    P0471 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 42
    Reset counter: 40
    Mileage: 125312 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:27:21
    Freeze Frame:
    RPM: 800 /min
    Torque: 40.0 Nm
    Speed: 0.0 km/h
    Pressure: 0.0 mbar
    Text: 112 C
    Text: 21 mbar
    Temperature: 15.0°C
    009299 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 42
    Reset counter: 40
    Mileage: 125312 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:27:21
    001139 - Exhaust Pressure Sensor 1 (G450)
    P0473 - 006 - Signal too High - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 25
    Reset counter: 40
    Mileage: 125188 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:19:06
    Freeze Frame:
    RPM: 2112 /min
    Torque: 200.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.32 V
    Mileage: 250 km
    Text: 132 C
    Pressure: 1001.1 mbar
  2. Re: Golf Mkv Exhaust Pressure Sensor G450
    Jan 2006
    Sounds like you need a new sensor on the DPF.
  3. Re: Golf Mkv Exhaust Pressure Sensor G450
    1840 Post(s)
    VCDS has the login codes and details in pop up boxes when you go into adaptations and login.
  1. Question Fitting A New G450 Sensor (Exhaust Pressure Sensor)
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2018, 02:16 PM
  2. Exhaust pressure sensor G450 parts shortage
    By Richs3 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-11-2013, 12:10 PM
  3. Exhaust gas pressure sensor
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2012, 10:37 AM
  4. Exhaust pressure sensor
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2012, 10:30 PM
  5. G450 exhaust pressure sensor
    By autobrake3 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-09-2011, 09:28 PM
