Thread: 1.9tdi AWX loss of throttle
  1. 1.9tdi AWX loss of throttle
    Jun 2007
    Tewkesbury
    A VERY intermittent problem. Throttle fails to respond, come totally off the pedal, then control returns. ESP light comes on, usually goes off when up to speed, but sometimes stays on until shutdown. Fuel consumption and performance have not changed. It usually happens when coming out of a car park or other slow speed stuff.
    Engine ECU fault codes are:
    18039/P1631 - Accelerator Position Sensor (G79): Signal too High
    17553/P1145 - Mass Air Flow Sensor (G70): Short to Plus
    Pedal has been replaced.
    Hair now being torn out!
  2. Re: 1.9tdi AWX loss of throttle
    12 Post(s)
    222 Post(s)
    This is usually water damage to the ECU.
  3. 1.9tdi AWX loss of throttle
    Jun 2007
    Tewkesbury
    Today it got worse. Thirty miles on the motorway with no problems. Back on the A roads and it was terrible. Limped to my mums house and called the AA.
    He read the same faults as me and suggested it was either the MAF or the pedal!
    Limped home with him following. Swapped the pedal back to the old one, still the same faults. Cancelled holiday.
    Disconnected the MAF, the only fault code showing is:
    17552/p1144. Mass air flow [MAF] sensor-670pen/short to ground
    But, it's drive able, a bit dull but still better than the Ibiza 1.2. No warning lights on.
    New MAF on Monday.
    Edited to add: no indications of water near the ECU.
  1. Please Help Occasional loss of throttle response above 2500 rpm
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2013, 09:38 PM
  2. loss of throttle pedal tempararly
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-12-2010, 10:34 PM
  3. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  4. Please Help loss of throttle response
    By adam8198 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2008, 08:59 PM
  5. Help! Allroad with loss of throttle
    By Giraffe in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-10-2007, 09:41 PM
