Thread: 1.9tdi AWX loss of throttle
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 1.9tdi AWX loss of throttle
    1840 Post(s)
    Any blue\white fur or other signs of corrosion?
  2. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    No, none at all. My customer put it back together so I could get it home. The ECU smelt bad again.
    I tried calling, then emailing the ECU Doctor, but have had no response, so I'm looking at Cartech Electronics for a replacement and recode.
    If a new ECU doesn't fix it, I'm afraid it'll be on eBay :-(
  3. Re: 1.9tdi AWX loss of throttle
    1840 Post(s)
    The ECU is in a sealed aluminium case and if it got hot enough to smell you would find it with your finger ends! It is more likely that it is the ECU relay which is getting hot and this is in the same box. If it had a fault that WAS making the ECU overheat then it is likely that you would just damage a new one. Instead of just randomly changing parts, why not spend that money on some professional VAG experienced diagnostic work?
  4. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    Two diagnostic companies not answering emails, but the ECU has tested ok.
    Suspected 5v shorting to earth in the loom. There is a bit of the loom outer broken behind the engine, we're going to strip that back and have a look.
  5. Re: 1.9tdi AWX loss of throttle
    Tewkesbury
    ECU refitted, everything worked ok for a couple of miles. No sign of any problems as far as I can trace them.
    It's been a bloody good car and doesn't really owe me much, so it's on eBay for Spares/Repair.
    I'm about to descend to a single VAG car :-)
  1. Please Help Occasional loss of throttle response above 2500 rpm
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2013, 09:38 PM
  2. loss of throttle pedal tempararly
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-12-2010, 10:34 PM
  3. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  4. Please Help loss of throttle response
    By adam8198 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2008, 08:59 PM
  5. Help! Allroad with loss of throttle
    By Giraffe in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-10-2007, 09:41 PM
