Thread: Turbo has started howling after accelerating, listen to this....
  1. Turbo has started howling after accelerating, listen to this....
    May 2018
    Blackpool England
    Hi All,
    My turbo has started making a loud howling noise that can be heard just AFTER accelerating. I went on Youtube and found a clip of exactly the same sound that someone else had posted and this is it:
    Mk5 golf tdi turbo howl - YouTube
    A few months prior to this I did keep having a problem with an intercooler pipe popping off connecting to the intercooler itself but I fixed that but ever since Ive noticed that the turbo sounds like its whistling at idle more than it did before (when I say whistle its more like a quiet police siren noise which I believe is common) however I got the impression the turbo was now whirling a little at idle when previously it didn't (only on gentle acceleration).
    One more thing to note is that the Emissions Workshop warning has come on a while back, I assumed it was caused by the clogging up of something when the intercooler pipe kept popping off as there was loads of black smoke kicking out of the back, however this warning came on at least a month before this sound started occurring.
    I know what you're thinking: "I hope I never buy a car off this idiot" but I would just like some advice on what it is and what I need to do to soldier it through.
    W
  2. Re: Turbo has started howling after accelerating, listen to this....
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    your symptoms could be EGR or intake throttle flap (V157) related, you should get a diagnostic scan as a starting point. If the car has being going into limp mode that could point to turbo VNT sticking but emissions warning more likely to be EGR related, however turbo howling worst case scenario could be the turbo itself, rule out the cheaper stuff first though with a diagnostic scan.
  1. Replies: 6
    Last Post: 07-02-2018, 02:08 PM
  2. Howling
    By acebundi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2012, 05:07 PM
  3. Golf 1.4 TSI Turbo Howling/Whine Noise at Low Speed/Revs
    By nnchokshi in forum Golf MK5 - 2004 - 2009
    Last Post: 15-10-2009, 09:38 AM
  4. What you listen to...
    By paul b in forum Chat - Completely Off Topic
    Last Post: 03-08-2009, 07:55 AM
  5. Failing turbo? What should I listen out for?
    By chrisgeary in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-01-2009, 01:45 AM
