Thread: A4 Avant B8 Rear Wiper
Results 1 to 10 of 13
  1. A4 Avant B8 Rear Wiper
    reading berks
    The rear wiper on my 2009 Reg A4 Avant has suddenly developed a mind of its own. Driving along in perfectly fine weather and it will suddenly start up for no reason and not stop! When it does occasionally stop it's not in the correct park position. Temporary fix in place - fuse removed. This is obviously only a short term fix while we have this fine weather, but has anybody any suggestions as to a permanent fix please?
    As an aside and possibly related, for some time now the manual tailgate release handle does not open the tailgate when it is closed. I can open it fine with the drivers door switch & the key fob, just not with the handle. When the tailgate is open though & I stop it part way through closing then the handle DOES reopen it. All very weird!!
    Any & all suggestions gratefully received please.
  2. Re: A4 Avant B8 Rear Wiper
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by mghassey View Post
    Seems to be a common issue. Here are a couple of threads that might help:
    Bonkers rear wiper Avant B8
    Question Rear Wiper
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: A4 Avant B8 Rear Wiper
    reading berks
    Many thanks, I'm afraid that makes dreadful sense! I'll have a look & see if I can spot a leak, combined with the Tailgate latch not working I was suspecting ECU problem, but maybe that's got wet too?
  4. Re: A4 Avant B8 Rear Wiper
    Apr 2009
    Had exact same problem, replaced with generic VAG one on eBay for 40 quid.
    Audi A4 Avant 2.0 TDi 2009
  5. Re: A4 Avant B8 Rear Wiper
    1837 Post(s)
    The rear wipers on the 8P A3 and 8E A4 Avant are a reliability joke, you can guarantee any one you see is either broken or if not, it has been replaced. When they leak screen wash, this damages the boot lock unit and on the A3 can collect in the tailgate and then when it is opened, the water runs down the sides, into the grommets and the roof lining staining the C pillar rims and eventually works its way down to the central convenience ECU where it causes the power supply pin to corrode off and so the ECU has to be replaced as well.
  6. Re: A4 Avant B8 Rear Wiper
    46 Post(s)
    I’ve just had to replace mine on my 2009 8P. Got 9 years and 210k before it gave up, think I did pretty well!
  7. Re: A4 Avant B8 Rear Wiper
    reading berks
    Have just received official diagnosis - as per other threads on here the tailgate wiper motor problem has been caused by the washer pipe leaking. Seems very poor design / materials to me for this to be as common as it appears.
    The malfunctioning tailgate release is apparently the control unit, as suspected. Tempted to not bother with that but you never know what else might be going so am having that replaced as well!
  8. Re: A4 Avant B8 Rear Wiper
    Mar 2015
    Knighton, Powys, United Kingdom
    Water gets into the wiper motor. Poor design, quite common on Audi's.
    Just had mine replaced under warranty by Audi.
  9. Re: A4 Avant B8 Rear Wiper
    1837 Post(s)
    Water is pumped through the motor through a rotating shaft, stupid idea!
  10. Re: A4 Avant B8 Rear Wiper
    May 2012
    Everywhere
    308 Post(s)
    Who is oem , please don't tell me they've stuck with French Valeo that have been failing for the last 20 years or more .
  1. a6 avant rear wiper
    By boidy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-01-2014, 02:29 PM
  2. Avant rear wiper arm too low
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2013, 01:59 PM
  3. Avant Rear Wiper
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-11-2010, 05:23 PM
  4. Avant rear wiper again.
    By vma99r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-01-2010, 04:18 PM
  5. Avant Rear Wiper
    By Cpt Shed in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2009, 10:20 AM
