Hi I have a Passat 2012 Estate (B7) that the dashboard lit up like a christmas tree, ran VCDS and have the following errors, I would be grateful if anyone is able to give me some pointers on what to fix as all the errors have happened at once; Many thanks
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VD24 0023
Revision: --H07--- Serial number: 00000005308831
Coding: 0004016
Shop #: WSC 05311 000 00000
VCID: 72ED9F8E6D38DBD41E-8026
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 35
Mileage: 202493 km
Time Indication: 0
Date: 2012.10.06
Time: 08:01:45
Freeze Frame:
Speed: 93.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.50 V
Bin. Bits: 00011111
Count: 34
Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 36
Mileage: 202493 km
Time Indication: 0
Date: 2012.10.06
Time: 08:01:55
Freeze Frame:
Speed: 93.0 km/h
Hex Value: 0x0001
Voltage: 14.50 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 36
Mileage: 202527 km
Time Indication: 0
Date: 2012.10.07
Time: 13:05:56
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 156
Hex Value: 0x0000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 195 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 377B6E9A46DA7EFCE9-8062
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 202493 km
Time Indication: 0
Date: 2012.10.06
Time: 08:01:46
Freeze Frame:
Voltage: 14.75 V
DU
Temperature: 19.0C
RPM: 1594 /min
Speed: 94.0 km/h
Speed: 94.0 km/h
Count: 0
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000646345
Coding: 0022167
VCID: 356764925CD68CECFB-8060
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 36
Mileage: 202493 km
Time Indication: 0
Date: 2012.10.06
Time: 08:01:45
Freeze Frame:
Voltage: 14.50 V
Count: 104
Speed: 94.0 km/h
Hex Value: 0x1268
Hex Value: 0x8004
Hex Value: 0x0101
End-------------------------(Elapsed Time: 03:24)--------------------------
