Thread: Coolant loss 1.9TDi 130 AVF engine
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Coolant loss 1.9TDi 130 AVF engine
    #11
    1841 Post(s)
    From the perspective of doing this DIY, you can JUST make it work financially IF you are keeping the car. Rebuilding the original head is a mugs game, it will not last unless you can have it Hot Isostatic Pressure impregnated after the refacing. This is a micro thin coating that prevents (sort of) porous surface seal failure and so the only sensible method is to fit a new head, AMC make some good parts and there are some Chinnese copies around that seem OK. A new cam kit is also very sensible, make sure it is billet not cast. Alternatively, the sooner all light vehicle diesel is scrapped the better my lungs will be.....
  2. Re: Coolant loss 1.9TDi 130 AVF engine
    #12
    Jun 2008
    Thank you for your reply Crasher. Some interesting things to consider there. What are my chances of taking the existing head off and finding that it doesn't need skimming or refacing in any way? And if so, would it be stupid to refit it?
  3. Re: Coolant loss 1.9TDi 130 AVF engine
    #13
    1841 Post(s)
    It MAY not be warped but the injector bores WILL be worn and to get a suitable surface finish for a new gasket it would need refacing.
  4. Re: Coolant loss 1.9TDi 130 AVF engine
    #14
    Jun 2008
    Thanks again Crasher!
  5. Re: Coolant loss 1.9TDi 130 AVF engine
    #15
    Jan 2017
    Dublin
    First of sorry to hear about the car
    I know this is of little help to you, But there are so many of these engines in scrapyards
    Would you not consider just replacing the whole engine with another Avf
    Most blocks are going cheap now
  6. Re: Coolant loss 1.9TDi 130 AVF engine
    #16
    1841 Post(s)
    Better the Devil you know than one out of a scrapyard...
  7. Re: Coolant loss 1.9TDi 130 AVF engine
    #17
    Jan 2017
    Dublin
    Ye, I know what you mean crasher.
  1. 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    By kingdegsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2016, 12:14 AM
  2. 2002 1.9Tdi Sport Coolant loss
    By fire3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2013, 08:18 PM
  3. 1.9TDI coolant loss - ATTN Crasher!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-12-2012, 09:31 PM
  4. Coolant Loss from A6 Avt 1.9TDI SE 115 AJM
    By Garthy13 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-06-2011, 08:59 PM
  5. 1999 1.9Tdi (115bhp) coolant loss
    By dulaman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2010, 03:32 PM
