Thread: Lowering s-line by 1"
  1. Lowering s-line by 1"
    May 2017
    Newcastle
    11 Post(s)
    I have just fitted some Rs6 20" wheels to my s-line avant and need to lower another 1". The problem I have had in past with cars that have factory lowered springs is the lowered spring kits just say -40mm from std and can be less on s-line cars. Anyone know of a kit that will give me 25 to 40mm on s-line without going down coilovers route?
  2. Re: Lowering s-line by 1"
    May 2012
    Somerset
    216 Post(s)
    Comfort wise what does Eibach Sportline offer ?
  3. Re: Lowering s-line by 1"
    May 2017
    Newcastle
    11 Post(s)
    They all give lowering about but have warning about could be less on factory lowered cars. I fitted set to my passat sport a few years ago and rude hight did no change.
  4. Re: Lowering s-line by 1"
    Mar 2014
    Cologne, Germany
    55 Post(s)
    Quote Originally Posted by Stbb748 View Post
    Eibach is your friend....their PRO-Kit is very good! The link below tells you everything you need to know. Happy to help with the german of you want. As one can see thee are many variations of the A6.....
    http://web2.carparts-cat.com/default...31=9627&330=27
    2017 Audi S6 Avant
    2016 Volvo XC60 T5 R-Design (wife's)
    1987 Volvo 780 Bertone (my classic!)
  5. Re: Lowering s-line by 1"
    May 2009
    Newcastle-under-Lyme Staffordshire
    41 Post(s)
    You need to first figure out exactly which suspension setup you have currently. The build sticker in the wheel well of the boot (or inside the service book) will tell you. Look for one of the following codes on the sticker:
    1BA, 1BE or 1BV
    1BA = Dynamic Suspension - standard on SE but an option you could select for S line
    1BE = Sports Suspension (20mm drop) - standard on S line
    1BV = S line Sports Suspension (30mm drop) - a no-cost option you could select when ordering S line cars, but not fitted as standard
    If you currently have 1BA (unlikely but possible) you could get a 20mm or 30mm drop by switching to the 1BE or 1BV components. If you currently have 1BE (which I assume is most likely) the obvious choice is to buy and fit the 1BV springs, shock absorbers and bump stops. If you already have 1BV then you're looking at a non-standard solution.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
  6. Re: Lowering s-line by 1"
    May 2017
    Newcastle
    11 Post(s)
    Looks like I have 1BE so should have 20mm lower than std hight. So I just need a spring that gives 45mm lowering ant that will give me the inch I'm looking for.
    Thanks fir help
  7. Re: Lowering s-line by 1"
    Mar 2014
    Edinburgh
    228 Post(s)
    I would be a bit more cautious of lowering it too much as the ground clearance is not great on these A6. I have the 1be also and I canít get into my folks driveway which isnít that steep and any lower it will be brushing, or worse, the hump type speed ramps.
  1. Question A4 s-line estate "57" plate suspension Vs Passat 170 Sport Estate "58"
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2012, 09:47 PM
  2. Is there a Lowering spring "How To"?
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2012, 06:59 PM
  3. Thinking of geting A6 Avant - 18" S-line vs. 20" S-line
    By thehorse in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-06-2012, 08:12 PM
  4. Vredestein Wintracs - do they fit "standard" S Line 18" wheels?
    By wj209980 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-03-2011, 10:11 PM
  5. 15" to 17" wheel upgrade....Need lowering???
    By Doctor-X in forum Wheels and Tyres
    Last Post: 04-12-2008, 09:14 AM
