Thread: New clutch time?
  1. New clutch time?
    Sep 2015
    Birmingham
    Current situation is Audi A4 Avant, 12 plate, 84k miles, 90% motorway miles. Accelerating on Saturday and still an issue in 3/4/5/6 revs jump up by about 300 RPM then drop back down by 300 RPM car then starts to accelerate as REVS increase. Car then seems to pull ok after that.
    Car booked in to main dealer next week for inspection. A local indy is quoting to replace clutch, DMF and seal after a test drive (ouch), also said there is a slight judder during acceleration which I have not noticed but will look out for next time I drive it. Annoyingly the car is 3 months out of warrenty....
    Does this sound like a diagnosis and fix for the issue for a car that only done 84K?
  2. Re: New clutch time?
    Malvern
    6 Post(s)
    Sounds rather like a clutch on the way out. Did you buy second/hand? 84k is early for this to happen in my experience. My experience is limited to 2.0 tdis though and the 3.0 litre might go through clutches more quickly if driven enthusiastically. Presumably the jump in revs you mention is after the clutch has been fully engaged?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    A4 B6 130 (6) Avant 2003(Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013
  3. Re: New clutch time?
    May 2012
    Somerset
    204 Post(s)
    3.0 tdi clutches are more robust even when remapped to
    750Nm as they are twin plate .
  4. Re: New clutch time?
    Sep 2015
    Birmingham
    Bought approved used from dealer at 33k with 2 year warranty, it's the 2.0. Yes jump in revs is when the clutch is fully engaged and I'm accelerating, it has started to slip post the initial jump in revs now. I think you're right it's just the clutch starting to wear which is disappointing as most of the miles I have put on it have been motorway only.
  5. Re: New clutch time?
    Sep 2015
    Birmingham
    So to bring the saga to a close.
    Service reports that the DMF had leaked grease on to the clutch which contaminated it and caused it to slip.
  1. Clutch Time Take 2
    By b8sline in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2014, 12:28 PM
  2. Clutch Time!
    By SattyA4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2014, 10:25 AM
  3. When is it time for a new clutch
    By gingernut352000 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-11-2011, 09:52 PM
  4. Question Time for clutch???
    By sammi49 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2011, 07:01 PM
  5. Clutch / DMF time
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2010, 10:07 AM
