Thread: Wheel bearing size
  1. Wheel bearing size
    Mar 2017
    Nottingham
    9 Post(s)
    I need a new rear wheel bearing but when I go to buy one everyone asking if it's a 30mm or 32mm inner diameter dose anyone know what fits my car, it's a golf gt sport 2.0 tdi 140 2007 bkd
  2. Re: Wheel bearing size
    106 Post(s)
    1813 Post(s)
    It changed on cars built after 24/04/2006 so yours SHOULD be 32mm but I have seen anomalies so we keep both sizes in stock as it is a common job.
  3. Re: Wheel bearing size
    Mar 2017
    Nottingham
    9 Post(s)
    Thanks very much
  4. Re: Wheel bearing size
    Mar 2017
    Nottingham
    9 Post(s)
    How much do you charge for part plus fitting, as I'm only around the corner from you
  5. Re: Wheel bearing size
    Mar 2017
    Nottingham
    9 Post(s)
    All done and fitted today it was the 30mm
  1. Hub nut and Wheel bearing bolt size
    By Bavers in forum Golf MK5 - 2004 - 2009
    Last Post: 27-05-2017, 03:30 PM
  2. A3 190hp . What wheel size, what tyres size would you buy
    By MR2BIG in forum Wheels and Tyres
    Last Post: 08-09-2015, 09:44 PM
  3. How To Change wheel bearing rear wheel
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 01:56 PM
  4. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  5. Rear Wheel Bearing and Torx Size
    By daveaustin in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 01:23 AM
