Thread: part number not on etka?!?
  1. part number not on etka?!?
    Jul 2008
    Lisburn
    15 Post(s)
    It's a t piece from the header tank on the asb engine. Can't attach pics but part 35 is the clamp that secures it etka just shows a dotted line to join the pipes no part ?!?! coolant cooling system; F 4F-5-006 001>>; Audi A6/S6/Avant quattro (A6Q) 2007 year Audi EUROPA 121046 any ideas?
    Stewart
    Last edited by swalker; 12-05-2018 at 02:28 PM. Reason: auto correct didn't like asb
  2. part number not on etka?!?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Where does the T pipe go? Maybe you need 13 position. You mean return pipe from coolant tank? There is no T pipe there. The sequence from the tank return pipe to engine is: clamp, pipe, clamp, pipe with T part.
    The only T pipe is at 13 position. I changed it myself to my BPP engine. The pipe comes with the T part on it so you can’t buy only T part since is made like that. You will need the clamp from position 31 too.
  3. Re: part number not on etka?!?
    Jul 2008
    Lisburn
    15 Post(s)
    Ah looking at it in front if the car 20 and 12 are the other 2 bits so 13 comes with t piece fitted? And that's an extra bit on it for part 5 if fitted?
  4. Re: part number not on etka?!?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Exactly. In each case you need number 13 if you have a T pipe.
  5. Re: part number not on etka?!?
    Jul 2008
    Lisburn
    15 Post(s)
  6. Re: part number not on etka?!?
    Jul 2008
    Lisburn
    15 Post(s)
    Thanks for that that was the correct part.
    Car is running better than ever - going for the not broke dont fix option so the only issue that is apparent is the reversing sensors - yes 2 one front one rear just to be handy..
    Thanks again
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Please Help Q3 2013 clock spring ETKA part number
    By Audidua in forum Q3
    Last Post: 30-12-2014, 08:30 AM
  2. ETKA Part Number Help
    By s liner in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2013, 04:47 PM
  3. Radiator fan not working - part number info needed! (ETKA?)
    By tates1979 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-06-2010, 10:32 AM
  4. VW part codes - Etka???
    By vwmark in forum Passat - Archive Topics
    Last Post: 02-12-2006, 10:47 PM
