Thread: PRNDS Flashing and gear stick stuck at P
  1. PRNDS Flashing and gear stick stuck at P
    Apr 2018
    London uk
    DEar All
    After the battery gone flat jump start the car since then not able to shift the gear stick from Parking. Changed the brake switch and after 4 days the fault came back again. I cleared it with VCDS but coming back after few days.
    Is it the ECU plying up or the battery gone south I do not have a clue?
    can anybody help me please I do not want to stuck middle of the motorway?
    many Thanks
  2. Re: PRNDS Flashing and gear stick stuck at P
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    What error do you have?
  3. Re: PRNDS Flashing and gear stick stuck at P
    Apr 2018
    London uk
    Address 01: Engine Labels: 059-907-401-BPP.clb
    Part No SW: 4F5 910 401 Q HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000CG 0010
    Revision: --H05--- Serial number:
    Coding: 0011382
    Shop #: WSC 02334 758 00200
    VCID: 2F6D37E7BE973E3CB1-807A
    2 Faults Found:
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 163981 km
    Time Indication: 0
    Date: 2017.01.17
    Time: 06:47:03
    Freeze Frame:
    RPM: 1071 /min
    Torque: 101.4 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Duty Cycle: 24.9 %
    Temperature: 7.2°C
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 13
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 10:20:47
    Freeze Frame:
    RPM: 1197 /min
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.45 V
    Bin. Bits: 00101010
    Torque: 249.6 Nm
    Bin. Bits: 00000100
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F5 910 155 R HW: 01J 927 156 JG
    Component: V30 0AN 2.7lTDI RdW 0010
    Revision: --H03--- Serial number: 00000000000527
    Coding: 0000001
    Shop #: WSC 02325 758 00200
    VCID: 3663028341CD0FF4F2-8062
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020872
    VCID: 65C195CFACEBB46C8B-8030
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 138
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:38:12
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4282
    Hex Value: 0x0024
    Hex Value: 0x01A8
    Hex Value: 0x00FF
    01119 - Gear Recognition Signal
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 149
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:46:31
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4282
    Hex Value: 0x0031
    Hex Value: 0x01AB
    Hex Value: 0x00FF
  4. Re: PRNDS Flashing and gear stick stuck at P
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Why did you change the brake switch? You have the steering angle sensor at intermitent error. You can try to adapt the sensor, maybe it’s a misscomunication with it since it’s intermitent.
  5. Re: PRNDS Flashing and gear stick stuck at P
    Jul 2013
    76 Post(s)
    You have a knackered glow plug, and the wiring to the clockspring (steering wheel) needs to be checked as it showing a intermittant break in the supply wire (this could be a break in the clockspring).
    The
    Gear Recognition Signal fault could be down to the gear lever fault as s in the other post.
    You must keep the topic in the one post to prevent the wrong info being given out when you open multiple posts for the same problem, as the true details can be missed.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: PRNDS Flashing and gear stick stuck at P
    Apr 2018
    London uk
    Thanks Dan
    I am new to the forum so did not know which place to post
  1. Please Help PRNDS flashing when parked and Gear stick stuck at P
    By WAWA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-07-2018, 11:24 AM
  2. Prnds light flashing
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2014, 10:05 PM
  3. Question Prnds flashing?
    By Shawrigg in forum Touran - Sharan - Caravelle
    Last Post: 13-04-2014, 09:44 AM
  4. Question PRNDS flashing
    By ChristopherF in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2011, 10:50 AM
  5. Please Help PRNDS Flashing
    By GJC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 10:36 AM
