I fitted a set of rear PSB polyurethane bushes when replacing the wishbones on my car last September. Over the last few weeks its developed an annoying creak from the front left suspension area. On further investigation the wishbone arm is moving backwards and forwards slightly in the polybush making the annoying creaking noise. Im going to strip it and check it over but it seems that the bush has failed, or I've damaged it when fitting it, which was a bit of a pain ! The arm seems to sit further out of the rear of the bush than the drivers side too - seems a bit odd although the drivers side was a Meyle wishbone and the passenger side a no name brand - maybe the source of the problem
has anyone else had this problem with poly bushes?
Brian
