Thread: PRNDS flashing when parked and Gear stick stuck at P
  1. PRNDS flashing when parked and Gear stick stuck at P
    Apr 2018
    London uk
    Dear All
    Sorry I am new to this forum
    can anybody help and give a right steer? I did the scan on last Saturday because the car gearstick was stuck in P and all the letters “PRNDS” were flashing so here is the scan
    Saturday,05,May,2018,16:42:22:35442
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
    VCDS Version: 18.2.0.3
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53
    56 61 62 6D 72 76 77
    VIN: WAUZZZ4F78N061924 Mileage: 186330km-115780miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media P
    layer 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: Cannot be reached 1100
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-BPP.clb
    Part No SW: 4F5 910 401 Q HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000CG 0010
    Revision: --H05--- Serial number:
    Coding: 0011382
    Shop #: WSC 02334 758 00200
    VCID: 2F6D37E7BE973E3CB1-807A
    2 Faults Found:
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 163981 km
    Time Indication: 0
    Date: 2017.01.17
    Time: 06:47:03
    Freeze Frame:
    RPM: 1071 /min
    Torque: 101.4 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Duty Cycle: 24.9 %
    Temperature: 7.2°C
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 13
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 10:20:47
    Freeze Frame:
    RPM: 1197 /min
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.45 V
    Bin. Bits: 00101010
    Torque: 249.6 Nm
    Bin. Bits: 00000100
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F5 910 155 R HW: 01J 927 156 JG
    Component: V30 0AN 2.7lTDI RdW 0010
    Revision: --H03--- Serial number: 00000000000527
    Coding: 0000001
    Shop #: WSC 02325 758 00200
    VCID: 3663028341CD0FF4F2-8062
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020872
    VCID: 65C195CFACEBB46C8B-8030
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 138
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:38:12
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4282
    Hex Value: 0x0024
    Hex Value: 0x01A8
    Hex Value: 0x00FF
    01119 - Gear Recognition Signal
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 149
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:46:31
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4282
    Hex Value: 0x0031
    Hex Value: 0x01AB
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Revision: 09010701 Serial number: 10601500900039
    Coding: 0000019
    Shop #: WSC 02323 758 00200
    VCID: 63C58BD7A2DFCA5C65-8036
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350JP077826041
    Coding: 0030002
    Shop #: WSC 00000 000 08192
    VCID: 2541D5CFEC6B746C4B-8070
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000000789103
    Subsystem 3 - Serial number: 0121.06.070000000100010447˙
    Subsystem 4 - Serial number: 010447˙
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000030290807
    Coding: 0001046
    VCID: 1C37F02BDF21B5A4E4-8048
    2 Faults Found:
    00657 - Positioning Motor for Central Vents (V102)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 26
    Reset counter: 112
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:37:56
    Freeze Frame:
    Voltage: 11.30 V
    Temperature: 16.0°C
    (no units): 31.0
    (no units): 64.0
    Temperature: 16.0°C
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 97
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:38:00
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0010101
    Shop #: WSC 02335 758 00200
    VCID: 326B3E93ADA513D4DE-8066
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H46 0390
    Revision: 00046006 Serial number: AUZ5ZBG3489423
    Shop #: WSC 00000 000 00000
    VCID: 1A3BF633D515CB94F6-804E
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0UA929
    Coding: 0013381
    VCID: 2959D9FF8073500C6F-807C
    Subsystem 1 - Serial number: 6332CSME2A71182F7
    Subsystem 2 - Serial number: 6342CSME2973655FE
    Subsystem 3 - Serial number: 6352QSME3C4C3839V
    Subsystem 4 - Serial number: 6362QSME3F500F17O
    Subsystem 5 - Serial number: 63734SME3A593121Z
    Subsystem 6 - Serial number: 63834SME3C46401D2
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H03000 Serial number: 90055072640024
    Coding: 0102141
    VCID: 275DDFC79667667C79-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
    Component: KOMBIINSTR. M73 H21 0240
    Revision: 00700000 Serial number: 72W553U97
    Coding: 2304458
    Shop #: WSC 00011 888 96745
    VCID: 2345CBD7E25F8A5C25-8076
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B07926818D
    Coding: F551BE57303A0600
    VCID: 2D512DEFB49B4C2C83-8078
    2 Faults Found:
    00317 - Rear Lid Control Module (J605)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 97
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:37:58
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H50 1060
    Revision: 00000000 Serial number: 364JQ077721331
    Shop #: WSC 00016 210 69841
    VCID: 3B7513B77AEFD29C0D-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00000000 Serial number: ES
    Coding: 0002682
    Shop #: WSC 02327 758 00200
    VCID: 2C5720EB8F81452494-8078
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H26 0210
    Revision: 02100026 Serial number: 01070243500000
    Coding: 0010491
    VCID: 3169319FA8A328CCA7-8064
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
    Component: Amp.-ASK-RD H07 0270
    Revision: S1200000
    Coding: 030000
    Shop #: WSC 02399 823 56573
    VCID: 285FDCFB5B79690470-807C
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000481665
    Coding: 0001103
    VCID: 5EB3BA2389BDE7B44A-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00000000 Serial number: g
    Coding: 0002810
    2 Faults Found:
    01964 - Control Module for Seat & Steering Column Memory (J136)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 31
    Reset counter: 113
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 11:37:56
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 29
    Reset counter: 153
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 15:12:55
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000531
    Shop #: WSC 02324 758 00200
    VCID: 204FC4DBF349914438-8074
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394J1077818285
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000150681
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 0709290939
    Coding: 344630393135313035442056413030373039323930393339
    Shop #: WSC 00000 512 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 10
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 12:54:03
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 12:57:13
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 12:57:24
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 12:58:13
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 185728 km
    Time Indication: 0
    Date: 2018.04.27
    Time: 12:58:22
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0002090
    VCID: 2E532AE3B99D3734BA-807A
    Address 6D: Trunk Elect.
    Cannot be reached
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0002090
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
    Component: Parkhilfe 4-Kan H09 0060
    Revision: 00H09000 Serial number: 06240726803976
    Coding: 0201006
    Address 77: Telephone Labels: 4F1-910-336.lbl
    Part No SW: 4F1 910 336 D HW: 4F1 862 335
    Component: BTA H09 1120
    Revision: 00H09000 Serial number: 00000007517735
    Coding: 1040021
    End-------------------------(Elapsed Time: 03:14)--------------------------
    I have a VCDS cable and clear the code from then it is fine but I have read on the forum the fault will come back
    Can anybody advise me what do I need to do?
    Any help will be much appreciated
    Many thanks
    WAWA6
  2. Re: PRNDS flashing when parked and Gear stick stuck at P
    Jul 2013
    76 Post(s)
    you need to check your battery first.
    it's most likey on it way out.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: PRNDS flashing when parked and Gear stick stuck at P
    1836 Post(s)
    And something is saying water ingress in boot to me, new battery, code it in, make sure it is getting circa 14v at idle and if it is, clear all the codes and run it until it plays up and then read again.
  4. Re: PRNDS flashing when parked and Gear stick stuck at P
    Apr 2018
    London uk
    Took my car to the garage and they said the gear stick and its assembly and linkage need to be replaced
    They are the with the knowledge
  5. Re: PRNDS flashing when parked and Gear stick stuck at P
    Jul 2013
    76 Post(s)
    I doubt that it is correct.
    Your scan showed no faults, i would have expected to see a intermittant fault if the linkage or gear lever was faulty as the switches are part of this unit.
    Your Scan
    Coding: 0000001
    Dan
  6. Re: PRNDS flashing when parked and Gear stick stuck at P
    Apr 2018
    London uk
    Finally I have got the car back from the garage and they have repaired the CVT ECU unit in the gear box and the car running fine. Ran the scan again today and the faults has gone Happy days
    Thanks for your help
  1. Prnds light flashing
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2014, 10:05 PM
  2. Question Prnds flashing?
    By Shawrigg in forum Touran - Sharan - Caravelle
    Last Post: 13-04-2014, 09:44 AM
  3. Question PRNDS flashing
    By ChristopherF in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2011, 10:50 AM
  4. Please Help PRNDS Flashing
    By GJC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 10:36 AM
  5. PRNDS light flashing
    By garysoul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2008, 12:25 PM
