Thread: LT35 Low power and Lumpy Idle with Logs
  1. LT35 Low power and Lumpy Idle with Logs
    Oct 2009
    Worthing
    Hi, A friends LT35 is performing a little poorly. Over all it drives OK but is generally low on power. Everything appears to be in working and usable condition with the van being reasonably well maintained over the years. A quick check of a few engine parameters on VAGCOM shows that the MAF and boost appear to be responding in general and no obvious non functioning sensors. There were a few DTCs which when cleared and after a short drive have not come back, but I've told him to swing by in a few days and see if they have cropped up. It hunts at idle and the log shows that what appears to be a cylinder fuel trim is hunting around with stutters at idle coinciding with the low and high points of the sweeping trim. I was surprised to see no obvious lambda and fuel pressure parameters in the available channels.
    Is anyone able to have a look at the attached logs and comment?
    TIA.
    James.
    Address 01: Engine Labels: None
    Control Module Part Number: 2D0 906 019 A
    Component and/or Version: 2,8l R4 EDC 0001SG 3713
    Software Coding: 00002
    Work Shop Code: WSC 02330
    VCID: 204E6491A0730C4595-4AE4
    3 Faults Found:
    18009 - Relay for Supply Voltage Terminal 30 (J317)
    P1601 - 35-00 - Implausible Signal
    16705 - Engine Speed Sensor (G28)
    P0321 - 35-00 - Implausible Signal
    17471 - Fuel Pressure Regulation
    P1063 - 35-10 - Control Range Not Reached - Intermittent
  2. Re: LT35 Low power and Lumpy Idle with Logs
    Oct 2009
    Worthing
    Bump!
    Van has cut out a few times this week but no fault codes appearing fwiw.
    Any help appreciated.
  3. Re: LT35 Low power and Lumpy Idle with Logs
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Has it got an in tank fuel pump and is this working?
  1. Intermittent power loss at certain speed/rpm, lumpy idle
    By Underwoodr in forum Golf MK5 - 2004 - 2009
    Last Post: 31-08-2016, 06:03 AM
  2. Oil Leak & Lumpy Tickover LT35
    By boisty in forum The Commercial Range
    Last Post: 16-08-2016, 01:23 PM
  3. Question Lumpy idle/slight missfire/lack of power.
    By Piggles in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-04-2010, 03:06 PM
  4. Please Help lumpy idle, retro fitting power steering.
    By simon1.4cl in forum Golf MK3 - 1993 - 1999
    Last Post: 05-10-2008, 09:46 PM
  5. TDI 110 - lumpy idle/no power - ideas?
    By charliemouse in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-08-2007, 11:10 PM
