Thread: Bleed brake
Results 1 to 10 of 10
  1. Bleed brake
    Feb 2017
    Tamworth
    I have changed the right rear brake calliper, the rubber flexi hose and replaced the steel brake pipe which goes from the right rear to the left rear on my 2004 MK5 Golf 2.0GT TDI and I can't get any brake fluid to come through the bleed nipplethe pedal stays hard when I release the bleed nipple.
  2. Re: Bleed brake
    1836 Post(s)
    Take the hose off of the caliper and check you have flow out of the hose. What make are the caliper and hose and who made the brake pipe?
  3. Re: Bleed brake
    Feb 2017
    Tamworth
    I have tried disconnecting the hose and also where the metal pipe connects on the left Side and no fluid the pedal is hard when disconnected
    they are standard callipers
  4. Re: Bleed brake
    Feb 2017
    Tamworth
    I had my friend make up the solid pipe from copper
  5. Re: Bleed brake
    1836 Post(s)
    Have you disconnected the new pipe, copper is not a good idea, Kunifer 10 is far better as copper can easily collapse when it is bent.
  6. Re: Bleed brake
    Feb 2017
    Tamworth
    I have disconnected the new copper pie where it connects to the original on the left hand side and still no fluid comes out
  7. Re: Bleed brake
    1836 Post(s)
    Did you clamp the axle flexi?
  8. Re: Bleed brake
    Feb 2017
    Tamworth
    I didn't clamp the flexi as I had to change it along with the solid pipe along e back axel
  9. Re: Bleed brake
    1836 Post(s)
    You need to work your way forward right to the ABS pump if necessary and see where the obstruction is. I remember one chap I had with this about 100 years ago and he had put a Golf 1 on axle stands and then could not bleed the one of the back brakes after converting to discs, we found his axle stand had just caught one of the two metal brake pipes tucked up near the front chassis leg and crushed it but you could barley see it.
  10. Re: Bleed brake
    Mar 2016
    Minervois, France
    53 Post(s)
    There is even a possibility that new pipes and hoses have plugs in their ends to keep them clean inside before installation.
    It wouldn't be the first time someone forgot to remove them.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  1. Bleed Nipple Head Stripped - C38 NSR Brake Caliper, 2002 Audi Allroad AKE Auto
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-03-2015, 10:40 AM
  2. Brake Caliper Overhaul, bleed nipple size required
    By UisT4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2014, 07:30 PM
  3. Brake bleed nipple size
    By Millerboy79 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2014, 12:02 AM
  4. Best way to bleed brake and clutch fluid?
    By aerotec in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-02-2013, 12:42 AM
  5. brake bleed order
    By merton1973 in forum 80 - 90
    Last Post: 03-01-2011, 01:29 PM
