Thread: Helllllp x reg polo 1.4 16v
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Right ive found out some more, 5th gear car hates it, can get 80 out of 4th then put it in 5th and speed drops cant rev properly and then i have to turn the car off, My other friends diag is coming up missfire under alll cyclinders?
  2. Re: Helllllp x reg polo 1.4 16v
    1840 Post(s)
    That gives me the impression of a fuel delivery problem, did you change the fuel filter?
  3. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Yeah so far coil pack was done thermostat spark plugs egr and throttle clean air filter fuel filter havent had chance to check the pump old fuel filter was black (cut it up) ran redex through it aswell
  4. Re: Helllllp x reg polo 1.4 16v
    1840 Post(s)
    When you replaced the thermostat why did you do this and did you fit a new cover, a full new housing or at least inspect the centre of the bridge to check it was intact and there was no hold in the middle where the locating pin engages?
  5. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Checked it all over and flushed the system till running clear cleaned of any old residue and fitted a new gasket, old cover looked fine ( replaced after using kseal)
  1. Please Help 1.2 Polo 55 55000 miles. - VW Polo engine mis fire cylinder 1...advice
    By Chris2013 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-05-2013, 01:43 PM
  2. Important Can we install polo 9n3's steering wheel to my 2004 model Polo 9N?
    By polo38 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2010, 09:32 PM
  3. my euro beeza n polo and the project polo
    By smiffy vw in forum Show 'n' Shine - Post your efforts here
    Last Post: 31-10-2008, 07:29 PM
  4. Wet (VERY !) Polo
    By missesbell in forum Polo - Derby - Lupo - Fox
    Last Post: 04-03-2008, 07:12 PM
  5. Club Polo & Performance Polo sho
    By stuart in forum Shows & Events
    Last Post: 18-07-2004, 03:47 PM
