Thread: Helllllp x reg polo 1.4 16v
Results 1 to 10 of 15
  1. Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Right i got a vw polo 1.4 16v x reg as a temp till i can afford another, has a very odd issue, when i reach 3100 3200 revs in any gear it stutters shuddering the car but goes fine after, ive changed plugs filter got some carb cleaner and cleaned the throttle body and egr valve, also as precaution added k seal service light was on so manually reset, has oil good coolant, removed the thermostat also, any ideas?
  2. Re: Helllllp x reg polo 1.4 16v
    16 Post(s)
    391 Post(s)
    So a 6N2 petrol Polo but which engine type code, AUB?
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Yes 6n2 unsure of engine code will have to check
  4. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Hi again i believe it is a AUA noticed the thermostat gauge drops when it does this i have also removed the thermostat
  5. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Right today i have replaced the thermostat and sensor as i read that could be an issue but just my luck its still doing it
  6. Re: Helllllp x reg polo 1.4 16v
    16 Post(s)
    391 Post(s)
    I think you should invest in some professional diagnostics work to try and avoid wasting money throwing parts at it.
  7. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Diag comes up with nothing unfortunatley
  8. Re: Helllllp x reg polo 1.4 16v
    16 Post(s)
    391 Post(s)
    Using which diagnostic system?
  9. Re: Helllllp x reg polo 1.4 16v
    May 2018
    Pensnett
    Was my mates diag hes a mobile mechanic, he assumes its the fuel filter will update tommorow, was creating a smell when hitting higher rpm, he got 80mph out of it were i was only getting 60
  10. Re: Helllllp x reg polo 1.4 16v
    16 Post(s)
    391 Post(s)
    If his gear is a generic OBDII unit it may miss some codes on yours.
  1. Please Help 1.2 Polo 55 55000 miles. - VW Polo engine mis fire cylinder 1...advice
    By Chris2013 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-05-2013, 01:43 PM
  2. Important Can we install polo 9n3's steering wheel to my 2004 model Polo 9N?
    By polo38 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2010, 09:32 PM
  3. my euro beeza n polo and the project polo
    By smiffy vw in forum Show 'n' Shine - Post your efforts here
    Last Post: 31-10-2008, 07:29 PM
  4. Wet (VERY !) Polo
    By missesbell in forum Polo - Derby - Lupo - Fox
    Last Post: 04-03-2008, 07:12 PM
  5. Club Polo & Performance Polo sho
    By stuart in forum Shows & Events
    Last Post: 18-07-2004, 03:47 PM
