Thread: 16 month old Q7 discs warping?
Results 1 to 10 of 18
  1. 16 month old Q7 discs warping?
    Dec 2016
    Harrogate, N.Yorks
    Hi all,
    I have a Jan '17 Q7 and it's done about 10k miles - we went away for three weeks and the car was left on the drive. When we came back there was some fairly serious brake judder going on. My dealer has inspected the discs and has said that the front pair of discs are warped - runout of 6mm (not quite sure what that means?). Because it's a 'wear' issue, it's apparently not covered by warranty so they've quoted about £1k for discs and pads.
    Has anyone else heard of whether the discs are prone to warping? The dealer is suggesting that it is due to excessive heat as a result of heavy breaking, but this is just the family runabout and I've not exactly been driving a Q7 like an RS4!! Any thoughts/comments appreciated, it seems really odd that they can just warp like that and it not be a warranty issue!
  2. Re: 16 month old Q7 discs warping?
    Mar 2018
    GB
    14 Post(s)
    That's a crazy amount of money for both parts and labour, get a quote from a decent garage should be less than half that. Audi don't make brake discs or pads so any decent make would suffice.
    Sent from my SM-G900F using Tapatalk
  3. Re: 16 month old Q7 discs warping?
    Sep 2016
    Devon
    31 Post(s)
    Quote Originally Posted by bill.wj.wilson View Post
    You can use a Bosch service centre.
    Q7 S Line 272 MY18
    Dayton Grey pearl
    Tech, trailer, Style pack
    Reversing camera
    21 inch Sport Wheels
    Sent from my iPhone using Tapatalk Pro
  4. Re: 16 month old Q7 discs warping?
    Apr 2016
    Edinburgh, Scotland
    26 Post(s)
    I've got quite a heavy right foot in my SQ7 and could be called "heavy" on the brakes at times and I've got no issues at almost 20,000 miles. Car was serviced a couple of months ago and the paperwork for the health check they do had a big green tick next to the brakes section. I would seek a second opinion from an indy if I was you, and / or push like crazy to get Audi to foot the bill - have they sent you a video of the discs? Seems to be the thing now when they find something - I got a video and bill for £1,600 for a new wheel and tyre after a pot hole incident; I took the car to the Wheel Specialist and got the wheel fixed and a new tyre through my Premia wheel/tyre insurance...and in total it cost me the excess of £10!
    I can't see how the brakes would magically become warped after sitting still for three weeks? Just on that, not driving it for three weeks may have allowed some crud and possibly a little bit of corrosion to build up on the discs - I get this on my Passat as it does 90% motorway miles then sits on my drive for days on end, after a few miles of driving it goes away, but it doesn't sound as if it's nearly as bad as what you're experiencing.
    Let us know how you get on, good luck.
    MY17 SQ7, Sepang Blue, 22s, and lots of toys.
    MY16 Passat Bluemotion GT, Reflex Silver, 19s, only a few toys.
  5. Re: 16 month old Q7 discs warping?
    Dec 2009
    Dublin, Ireland
    14 Post(s)
    interesting! I had repeated, shocking misdiagnosis of brake judder issues by reputable Audi/ VW garages on my previous VW Phaeton. I drove it fast but smoothly so little if any hard brake use. In summary I had discs replaced under warranty (twice) due to vibration issues. The issue reappeared, so I did some internet hunting.
    As I recall, brake pad material interacts with disc surface and can be "patchy" depending on bed-in process.
    To solve my problem the solution was simple. Get an empty road (or better a private road) and from 100kph brake aggressively but not engaging ABS to almost standstill. It's important not to come to a standstill. Do this until the brakes are HOT. In my case I could smell the pads. I went for a drive to cool things down with very light brake application.
    It sounds a bit crazy, but this solved the problem permanently. It appeared my smooth driving style did not facilitate a proper bedding in by the pads/ discs. I had explicitly raised this issue with VW and they dismissed this as being impossible.
    Do some internet googling and there are some youtube videos on this also
    Phaeton is somewhat similar to Q7: AWD/ 3L V6/ 2000Kg so brakes are pretty big to match. High consumption of brake components is not inevitable on a heavy car. It's all about driving style. I did years of "motorway" speed driving on a 2000kg Phaeton but wafted around town: pads typically lasted 40,000 miles.
    It's worth a try. You have nothing to lose.
    EDIT
    I just re read the original post. Runout is the deviation from "flat": obviously a perfect brake disc will be perfectly flat. 6mm of runout I would think is impossible. I do not think the disc would pass through the pad gap with 6mm runnout. Maybe 0.6mm?
    The article below on brake function is one of those I viewed when I had my problems: very useful and in my experience accurate.
  6. Re: 16 month old Q7 discs warping?
    May 2012
    Somerset
    193 Post(s)
  7. Re: 16 month old Q7 discs warping?
    Sep 2016
    Devon
    31 Post(s)
    I had an A6 c7 which was a demo and had been on the forecourt for a few weeks. I started to feel a light vibration under braking and had a master tech to a drive with me.
    He stated that the new wheels donít offer as much weather protection so rust is a bigger factor than years gone by. When you leave the car the surface rust can, not always cause intermittent wear which can result in what appears to be warping.
    This doesnít seem right and I think a letter to Audi is in order
    Andy
    Q7 S Line 272 MY18
    Dayton Grey pearl
    Reversing camera
  8. Re: 16 month old Q7 discs warping?
    Dec 2016
    Harrogate, N.Yorks
    Thanks all, they showed me the Audi cam and you can see the needle moving as the rotor is turned, so I suspect it isn't just corrosion, but really surprised at the 'extreme heat' argument for warping. Surely the discs are designed for this type of car and have over engineering built in? I do think following this up with Audi is worth it though - even with a third party garage I'll be looking at several hundred quid for the whole job, which I really feel should be a warranty issue.
  9. Re: 16 month old Q7 discs warping?
    Dec 2009
    Dublin, Ireland
    14 Post(s)
    Can you see how much the meter deviates. I went to the bother of getting a run-out meter when I had problems, and I discovered that no disc is perfect. Some of the BS technicians feed back is sad. My experience is everything must be solved by "replacing the part".
  10. Re: 16 month old Q7 discs warping?
    Dec 2016
    Harrogate, N.Yorks
    In the AudiCam video you can see that the needle travels between positive 2 and negative 4 on the little dial. I've just read in depth through that article that Gazwould has posted and it seems to make sense to me. I might well try as the article and FortyPlus have suggested and see if that makes any difference. It will save me a fair amount of money if it works, what have I got to lose!
  1. Question Pagid Brake discs warping
    By acebundi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-09-2014, 08:44 PM
  2. Audi S5 keeps warping brake discs every 3 months!!!
    By adrianp in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 31-08-2014, 09:23 AM
  3. Brake Disc warping - help!
    By petw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-08-2010, 09:53 PM
  4. A3 Keeps warping discs
    By SimonPopp in forum Audi A3 - Archive Topics
    Last Post: 03-02-2008, 04:42 PM
  5. Warping Front Discs
    By mwerky71 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-01-2008, 07:47 PM
