Thread: Help Identifying noise
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Help Identifying noise
    #21
    Dec 2011
    East Grinstead
    Quote Originally Posted by FrenchAudi View Post
    I rather hope they'd have enough sense to keep their head down and I meant drive slooowly
    I still wouldn't want to volunteer!
    I toyed with the idea of strapping a phone under there to see if i could see what was happening. I still haven't ruled it out
  2. Re: Help Identifying noise
    #22
    Oct 2009
    Ashford Kent s,e England
    9 Post(s)
    I think FrenchAudi is on the same track as me, either something that has been inspected previously, has been mis-diagnosed as ok, or you really need the car over an inspection pit and somebody replicating the issue with a second somebody thoroughly inspecting from below.
    I personally would try to do this before laying out the cost of new struts, which could potentially be an expensive waste of money and time.
    Good luck
    Stuart
    ps, thats also a good call on the fitting and locking in, of certain bushes, ie, bottom links, antiroll bar etc, when not weight loaded sufficiently
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  3. Re: Help Identifying noise
    #23
    Dec 2011
    East Grinstead
    Quote Originally Posted by fourringsrus View Post
    Good luck
    Stuart
    I've pretty much run out of things to look at that are visible. There's nothing that's been undone or replaced that hasn't been checked for torque and there's no movement in any of the older control arms.
    All control arms were torqued under load.
    The worse it gets the more it sounds and feels like the struts (or the strut on that side) and they aren't that expensive so they may as well get done anyway. If it isn't them it rules them out and I then have fresh suspension all round (the garage told me my back end, that's the car not me, was a bit bouncy about three years ago so it's not a big deal to replace them all).
    It's being looked at by the garage on Saturday and if it isn't the struts then I can send them back since they haven't even been shipped yet so I suspect they won't arrive before then.
  4. Re: Help Identifying noise
    #24
    Dec 2011
    East Grinstead
    Well I dropped the car off at the garage and they phoned me five minutes later to tell me that another customer has driven into it.
    I swear this car is cursed
  5. Re: Help Identifying noise
    #25
    Mar 2016
    Minervois, France
    27 Post(s)
    I also had a jinxed car from Neckarsum - a Ro80 - collected new from the factory in 1968.
    I was rear-ended on the M1 a week after we bought it. The other driver was still unconscious weeks later, it wasn't his car, and the UK agents for the German insurance co., wouldn't do anything until they found who insured it. So three insurance companies were involved, one of them unknown, and no-one would do anything.
    I took it back to Neckarsulm, on the grounds that they were the agents for the German insurance co., where they reluctantly arranged the repair, but the garage which repaired it backed it into a wall on the day we collected it a few weeks later.
    He pinched a replacement boot lid from a customer's car, so we drove away, but soon realised it was a bodge. The door seals whistled, the steering was weird, and it behaved strangely on corners. By now I had taken out UK insurance, so asked them for help regarding the hidden faults from the previous repairs. Now four insurance companies.
    Took it to the AA for a report, but on the way back was rear ended in Manchester! Now five insurance companies were involved.
    The AA recommended having the body aligned on a jig. The insurances agreed to this, so it went to a specialist in Manchester.
    Went to collect it some weeks later but someone had broken the key in the steering lock, which they had cut off, and were waiting for a new lock from Germany.
    I eventually got it back, having had the use of it for only a couple of weeks in the year I had owned it, but it never felt the same again.
    We used it for another 8 months, driving long distances between the UK, Spain, and Algeria. It looked great, but it wasn't the car it should have been, so I sold it to an American in Mallorca.
    He hit a tree and wrote it off shortly afterwards. Definitely a jinxed car. I had two more, the last of which I rebuilt and now belongs to a collector in Japan.
    1996 A4 Avant 1.8T engine code AEB automatic with 58,000 kms - 36,000 miles on 1/1/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  6. Re: Help Identifying noise
    #26
    Dec 2011
    East Grinstead
    OK you win on the cursed car front
    Mine only has superficial damage but it is a pain.
    Garage could find nothing wrong with it, all control arms and mountings are free of play. His best guess was also a bolt that hadn't been tightened properly. I mentioned the suspension struts and he said it was possible. It wasn't helped by the fact that all my messing about had got some grit behind the brake pads and that was making a noise as well to cover up the other noises!
    I tightened absolutely everything on that side this morning (and cleaned the brakes) and the brake noise has gone but the clunking remains.
    I'll put the new struts on when they arrive and I'll take it from there.
  7. Re: Help Identifying noise
    #27
    Mar 2016
    Minervois, France
    27 Post(s)
    Do what I did nearly two years too late!
  8. Re: Help Identifying noise
    #28
    Dec 2011
    East Grinstead
    I need it to last another two years, then my daughter will be driving and we can share a car (something small and cheap!)
    I love this car when it's working properly
  9. Re: Help Identifying noise
    #29
    Mar 2016
    Minervois, France
    27 Post(s)
    Good luck then! Me, I'd wait until the fault becomes obvious.
    If I bothered about all the odd grunts and rattles from my VW I'd go nuts
  10. Re: Help Identifying noise
    #30
    Dec 2011
    East Grinstead
    I'll report back!
  1. Question Identifying where the issue is
    By cxite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2015, 09:50 PM
  2. Help identifying gearbox oil,please...
    By AN AUDI FAN in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-04-2015, 07:52 AM
  3. help identifying car.
    By Ben in forum Chat - Anything with wheels
    Last Post: 24-09-2011, 02:19 PM
  4. Turbo identifying
    By richard3009 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2009, 12:50 PM
  5. Please Help Help with identifying part
    By devereux in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 10:33 PM
